pilotswife
Active member
- May 6, 2002
Wrong, wrong wrong! There was a big discussion about this a while back on this board. Link to other thread.ASH said:And yes they can
liv'n_on_credit said:Wrong, wrong wrong!
They explained it as approaches being too intense to log them without touching the controls. There's a huge difference between talking someone through an approach and actually doing it with your own two hands.
MetroSheriff said:Too intense to log???
Did you forgot to add the /sarcasm after that statement?
mizzouguy said:No you cant log an approach a student flies. It would be the same as logging instrument time when he/she is under the hood
I hope you are joking right??? You do know that you as PIC are ultimately responsible to "see and avoid" What do you do on a solo when old man larry decides to go flying vfr w/ no transponder and your staring at the instruments with a frigg'n hood on?pavelump said:But then how do you log the time when you're solo under the hood?
