Hawker to Hawaii?
OState597
Hello to all...
Anyone have any thoughts or experience with a Hawker 800A from SFO to Hawaii? (destination island not known). We've converted it to what they now call a Hawker 800SP (special performance) due to the Av.Partners blended winglets, which saves me about 7% fuel savings.
I'm quite aware of the wet footprint issue and all the etc's that apply and the "what if's" that could occur. I'm just looking for anyone thats done it and can recall your landing fuel, headwinds going west, time of year you did it and so on.
Anything helps, thanks!
No experience in doing it in a Hawker but if it isn't obvious and you can't find the info from the manufacture, sounds like a bad idea to me. I think you have the wrong airplane for the job.
This news release was also referenced in November BCA magazine
http://newsroom.hawkerbeechcraft.co...s-etops-exemption-for-mid-size-hawker-models/
You're posting in corporate forum so I'm assuming you're part 91 so you can do what you want but HBC seems to think it should be possible even for Part 135. FAA can make the final call on that later. Do you have long range O2 bottle? Will that support crew and pax in event of loss of pressurization? From what (little) I know about the 800/900 Hawkers that may be the limiting factor and NOT planning for an engine failure.
I know of at least one 900XP that has done it severall times.
The 7% savings is over the course of what? Are you talking monetary or range?
I used to do it in a straight 800A (Part 135 air ambulance), but not in the winter. We went to Cold Bay Alaska and down from there in the winter. We had the Aviation Partners winglets and always had a dry footprint. I will say, it was close a few times though.
Call and talk to a pilot at Air Med. They do it all the time from what I understand. I'm amazed at the places they go in a Hawker (fine aircraft - but not really designed for transoceanic). Here's the contact info. I do have friends that have done it in a Hawker before out of KOAK or KSFO. It is not like flying the NAT tracks where you are stuck at an altitude and a Mach number. You can get altitude changes to take advantage of performance and winds. With all the ADS-C equipped aircraft out there, your wind data should be pretty good (from Universal, Arinc, Jepp, etc.).
http://www.airmed.com/home/
Toll free: 800-356-2161
If you are curious, here is a link to where they have been in a Hawker.
http://www.airmed.com/why-airmed/where-we-have-been.cfm
Hawker to Hawaii
Remember that for 135 you can't be more than 180 minutes from a diversionary airport, single engine or develope an ETOPS (ER) program and get it approved. California to the islands (using Santa Barbara and Maui) that means you have to be faster than 375 knots TAS single engine and I don't think a Hawker can do that.
TransMach
I used to fly for AirMed international. We flew 800A's from Oakland to Maui and HNL, but only in the summertime and sometimes not even then. I can't recall the max head wind now, but we would routinely go to Cold Bay Alaska and come down from there. The Hawker with the Aviation partners winglets can be ETOPS compliant but will never be ETOPS certified.
We evaluated the leg in our 800A with the API winglets and ultimately decided against it. We replaced our SP this year with an 850 and we're still not comfortable with it. Anything over a 60/65 kt headwind was a no go and the only way to do it was with supplemental o2. It's just really not the airplane for it, regardless of what HBC or API say. The only Hawker I'd even consider using is the 900XP. There was an operator in SDL who did it quite often in an 800XP without any problems. He studied the numbers backwards, forwards, left and right and had planned for literally any contingency. I guess it all depends on your comfort zone. I would also try to get a hold of an AirMed guy, they seem to be a reputable operator and fly their SPs all around the world.
At the end of the day, the best way to deal with the issue of trying to fly a 2000 nm +/- airplane on a trans-oceanic 2000 nm leg, on a profile like this is to BUY a 3000 nm airplane. End of story.
Sometimes being able to tell the boss in the back...any day, any time, we can do the leg, goes a LONG WAY!
Well said...He mentions a Falcon 50 quite often these days. Maybe I'll just push that idea a little harder.
Plus 50s are on sale these days... But then I guess most planes are, but I am amazed at the prices I see straight 50s and even EXs going for.
MT
MT
Very true, I saw a early serial number 50 for sale a couple of weeks ago for $1.5 million. I realise it is an early serial number, but still, all that performance for one and a half million bucks.
Name another type of aircraft that has Falcon 50 performance, including range, for that kind of money. I can't. The lowest priced 50EX I've seen lately was for under $9 million. But when one reaches that price area, there are other aircraft that can compete with the 50EX.
So for the money, the straight 50 is most likely the best buy out there today.
I can remember back a few years ago, it was hard just to find a Falcon 50 for sale, let alone a 50EX.
If you look at a straight 50, make sure it has the service life extension inspection done.
I would think that it would be a given that one would have to spend some money on any straight 50 that would be that early of a serial number. In this case the 50 I am referring to has a steam gauge cockpit, except for the updated FMSs.
