starcheckdriver
- May 13, 2004
Question about the GYPSUM DP out of Eagle, Co (EGE):
The DP requires a climb gradient be met for runway 7 and 25, unless the weather is 4100-3 and you can climb in visual conditions. Each runway provides a procedure to follow and then says "or. . . Climb in visual conditions to cross the airport northeast bound at or above 10,500..."
However, there is a FDC NOTAM out that a visual climb on this DP overhead the airport is not authroized (NA).
The question is this....Based on the NOTAM, does that mean ANY visual climb when issued this DP (assuming you have the 4100-3) is NA, or just a visual climb overhead the airport? In other words, assuming the 4100-3 wx requirement is met, can you still climb out visually following the DP and not overflying the airport?
Or, because of this NOTAM, are you forced to meet the climb gradient even in wx conditions better than 4100-3?
