islandpirate
I will on the 1st date
- Jan 6, 2005
Rumor floating around that the System CP at GIA FAILED his 441/PC/Checkride and had to redo it under threat of termination if it was failed a second time. Anyone out there know if there is any truth to this? Confirm or deny?
Karma can not be fooled...
How much do you have to pay to be chief pilot at gulfstream?
How the f can you fail a 1900 check ride. It's a seminole with turbine engines, not even a gps, and a crappy efis that takes about 5 minutes to learn what it can do if it has auto pilot.
...And Karma has a new target.
Carefull guys, anybody can fail a ride, ANYBODY.......
F Karma... the good Lord himself is gonna take care of this one. Most failures on check rides are usually over stupid stuff like forgetting to change a frequency or doing a procedure turn incorrectly. It can happen to anyone.
I'd say it's closer to a Baron with turbine engines...
Whats up brother. You know you can rip that dude a new a$$. Give me a shout.deleted. cause this is just too easy...
Q/F
I had a GIA 1900 roll to the end of an 8500 ft strip causing us to go around the other day. Everyone else made the turn about mid field. He was told several times to clear the runway but slowly rolled all the way to end. Thank you very much.
