Ground CFI Ticket
AGI-IGI certification
It is not a "ground CFI" certificate. It is a Ground Instructor certificate.
CFIs only need to take the writtens, complete an 8710 and take it and their written test reports to FSDO. You will leave with a fresh Temporary. Your CFI is evidence that you have taken the FOI written.
Hope that helps. Good luck with the writtens.
Flyin Tony said:
When I took the Insturment written, I took all the Insturment ones also ie. FOI (i think thats the one for the CFII) and the IGI. I have the IGI test results sitting right here. So what do I do with it. Can I teach IFR Ground school at my FBO? Or whats it good for. I just took them all because all the test were kinda the same and I pass them all the first time. Do I take my IGI results to the FSDO. So what will the FSDO give me? Thanks for all your help guys
You must pass the Fundamentals of Instructing (FOI) written exam to receive any kind of instructor certificate. Take your IGI and FOI reports to FSDO with an 8710 and you will be issued a Ground Instructor certificate with an Instrument rating.
When was it changed that BGI + IGI no longer results in an AGI-IGI certifcate?
Ground instructor privileges
dasmith said:
Incidentally, none of these are required for teaching a ground school. There´s a guy in tampa at the Univ So Fla campus with a private pilot teaching the ground school.
But he cannot sign off anyone to take the written.
Ground instructor certificate advantages
stlpilot said:
Anyway if I remember right the only advantage of the ticket is that if the folks you sign off fail the written it wont count against your pass/fail record? Is this the only advantage of this certification?
One advantage is that a ground instructor certificate does not expire, though 14 CFR 61.217 requires a ground instructor to be current. That is a change from several years ago.
In my case, I could get a signoff and then resume teaching ground school and sim, which could be a way for me to become active in aviation again. So, the fact that ground instructor certificates do not expire can be valuable for many people.
Of course, a ground instructor certificate is just one more credential to put on your resume.
Gold Seal CFI
Weasil said:
Hey Bobby, you forgot to mention that the AGI was needed when you got your GOLD SEAL.
You are absolutely right. Gold Seal CFI requirements are set forth in AC 61-65D:
18. GOLD SEAL FLIGHT INSTRUCTOR CERTIFICATES. The specific requirements for the gold seal flight instructor certificate are contained in FAA Orders 8700.1, General Aviation Operations Inspector’s Handbook, and 8710.3C, Pilot Examiner’s Handbook. Flight instructor certificates bearing distinctive gold
seals are issued to flight instructors who have maintained a high level of flight training activity and who meet special criteria. Once issued, a gold seal flight instructor certificate will be reissued each time the instructor's certificate is renewed. Applicants for gold seal flight instructor certificates must meet the following
requirements:
a. The flight instructor must hold a commercial pilot certificate with an instrument rating (glider flight instructors need not hold an instrument rating) or an ATP certificate;
b. The flight instructor must hold a ground instructor certificate with an advanced or instrument ground instructor rating; and
c. The flight instructor must have accomplished the following within the previous 24 months:
(1) Trained and recommended at least 10 applicants for a practical test, at least 8 of whom passed their tests on the first attempt;
(2) Conducted at least 20 practical tests as a designated pilot examiner, or graduation tests as chief instructor of a 14 CFR part 141 approved pilot school course; or
(3) A combination of the above requirements. (Two practical tests conducted equal the credit given for one applicant trained and recommended for a practical test.)
(emphasis added)
Another good reason for getting a Ground Instructor certficate. Really, it's very little trouble and the writtens are repetition of exams all CFIs have already taken.
No need to reduce down. It's always been:
14 CFR 61.197(a)(2)(i)
§ 61.197 Renewal of flight instructor certificates.
(a) A person who holds a flight instructor certificate that has not expired may renew that certificate by -
(2) Presenting to an authorized FAA Flight Standards Inspector -
(i) A record of training students showing that, during the preceding 24 calendar months, the flight instructor has endorsed at least five students for a practical test for a certificate or rating and at least 80 percent of those students passed that test on the first attempt
AvBug, I think you are mixing up requirements to renew a flight instructor certificate and requirements to earn a Gold Seal certificate.
dasmith said:
So I thought that the FAA standardized the gold seal requirement with the scripture that avbug quoted...
ds
It doesn't say anything about gold seal in the regulation that avbug quoted. There isn't anything in the regulations about the gold seal requirements, it's only found in the AC bobbysamd quoted.
