A route MORA is specific to that route and will give you 1000-2000 clearance above all obstacles within 10 miles of the route centerline and within 10 miles of the radius around the route endpoints.
A grid MORA gives the same clearance but over all obstacles within a latitude/longitude grid on Jepp charts or WACs as applicable.
In either case, if the obstacle is less than 5000' msl, the clearance is 1000' and 2000' otherwise.
