I have an interview on April 8. Any info about the structure of the interview, the sim ride, possible bases, which aircraft you are most likely to go into, etc. Anyone else have an interview on the 8th?
www.aviationinterviews.com
Most everything you need is on there. Sim ride unlikely, take the Beech if you have any choice at all, and Denver is essentially the only remaining base.
They only ask a single question at the Great Lakes interview. I'll give you the question and even the answer:
Question: After a nuclear winter, what are the only two things that will be left remaining on earth?
Answer: Cockroaches and Great Lakes Aviation.
Kidding, kiddding.....Sorry. A Great Lakes Captain told me that one when they were going through that FAA maintenance fiasco a few years ago.....and GL is still here today.
Very unlikely that there will be a sim ride..base will be DEN unless they decided to open up a PHX base, which is just a rumor right now..as for the interview....KNOW your jepp charts and approach plates and everything about them, otherwise it will just be your standard hr questions..good luck
