GPS thru a heated Windshield
LJ45
Any one use a GPS antenna for a EFB thru a Heated windshield, such as a Learjet 45?.....thanks,
I'm not sure if this is relevant, as I'm not sure how the Lear's windshield heat compares, but I had a handheld hiking GPS on the dash of a Beech 1900 under a heated windshield, and it had no problem at all acquiring the satellites.
I've tried to use a GPS under the windows of the A320, and I couldn't get a signal. I even tried the back windows which are just anti-fogged, not heated...no luck.
It worked fine when I used a passenger window or the forward entry door window.
I am using a antenna for XM weather and a bluetooth gps reciever through the windshield on a Beechjet with no problems.
Is that a Garmin 395? How well does it work? Looking for an inexpensive solution to getting in-flight wx data - either through a portable handheld solution like that or a pernament receiver/antenna with a PDA plug-in for display. Aircraft = BE-B200 with Collins EFIS 85 & UNS-1M.
cvs fly look at the thread with Wx Xm right below this one
Using the WX Worx portable XM weather receiver bluetoothed to our ADR FG- 4000 efb. Only problem with reception using the portable antenna has been in the Northeast, both of their Satellites are over the equater south of Atlanta and Phoenix. I have a permanent antenna installed and will start using it in a week or so, as soon as I get the coax connector in from DAC(Thanks to Big D).
Currently use a XM Satellite radio, with the antenna below the windshield on a Lear 45. Works great going coast to coast, do not go to the North East much.
no luck with GPS
Our IR-310 USB GPS didn't work thru the windshield on the Lear 45 and couldn't get it to work in the back thru a passenger windshield.
As soon as I stepped out of the aircraft it started working, I guess too much interference.
Oh well... guess we will need a converter from the FMS to have aircraft position on the EFB for XM weather.
hey lj45 that link you gave me with the serial share works awsome.
Truely a ton of info on the tablet now. Actually gives me something to do. :)
I suspect though we are going to have to mount the antenna. It just looks too goofy with a wire on the dash and doesn't work that well headed north from florida.
