satpak77
Marriott Platinum Member
- Dec 2, 2003
The DME, ADF, or intersection names or identifiers must be retrieved from the database, and pilots must ensure that data is current in accordance with the aircraft flight manual supplement or approved operations manual.
There's two pieces to the use of,say DME. In both cases =something= has to be in the database. Either the DME named intersection or waypoint that's, say at 6.2 DME or the facility that is producing the DME, like the XYZ VORTAC. Take a look at AIM 1-1-19.f.1.c (including the notes). It talks about the alternate ways to use DME. One is using the DME source as the active waypoint.DC8 Flyer said:That seems to me, you can't use the GPS like a DME receiver, ie for raw distance readout, while doing an approach. The fixes would have to be in the database. The approach the OP posted is a timing approach but has lower minimums if you can ident the 5DME fix off of HAR.
midlifeflyer said:There's two pieces to the use of,say DME. In both cases =something= has to be in the database. Either the DME named intersection or waypoint that's, say at 6.2 DME or the facility that is producing the DME, like the XYZ VORTAC. Take a look at AIM 1-1-19.f.1.c (including the notes). It talks about the alternate ways to use DME. One is using the DME source as the active waypoint.
b350, this was a good conversation. This is still really so new that the way the FAA looks at this changes as we go along. What wasn't allowed yesterday is allowed today (and maybe vice versa). And, in some ways, the AIM language isn't as clear as it could be. So kicking it around is pretty worthwhile.
Besides, look at how many posts we made disagreeing with each other without even once coming close to calling each other an idiot![]()
Yeah, but were you thinking it?midlifeflyer said:Besides, look at how many posts we made disagreeing with each other without even once coming close to calling each other an idiot![]()
LOL! No, I really wasn't. It probably doesn't come through in print, but I didn't have my usual ingratiatingLead Sled said:Yeah, but were you thinking it?![]()
'Sled
mflyer said:I would use the DME and use the GPS as a cross reference. Even though there is probably not much difference between the two...I guess one thing to think about is the location of the actual GPS reference point on the field! I have seen them located in various places!
A Squared said:I think that something needs to be clarified here. In order to use gps for a substitute for DME in any case, the actual location of the actual, physical navaid must be used. IE if you're looking for distances relative to the ILS DME at XYZ airport, you had better be sure that you have the coordinates of the XYZ ILD-DME antenna dialed up in your GPS, not the KXYZ ARP (airport reference point)
DC8 Flyer said:That location has to be pulled from the database, you cannot plug in the LAT/LON of a LOC/DME antenna and be "legal" to use the GPS for DME if so required on the approach.
