midlifeflyer
- Jan 20, 2003
- KTTA
- Commercial ASEL, CFI-ASE, CFII
CFIse said:Got something else you'd like looked at?
midlifeflyer said:Stay tuned. I hear there's a NOTAM coming...
Not necessarily. Get past the obvious nonsense of saying things likeCFIse said:The advocates seem to believe that whereever they come from, if they can be "established" on something then they don't need to do a PT
to support the argument that if the term NoPT is =not= used the procedure turn is still not required.the term "NoPT" is used with the appropriate course and altitude to denote that the procedure turn is not required...."
is an interesting point. Not necessarily IAFs, but the concept that, TAA aside, if you are on a =published= approach segment that is aligned in direction and altitude with the final approach course (like the BAGBY feeder on the GUM 26L approach), you do not need to do a PT. It's pretty obvious that it =shouldn't= be needed.You will not find "NoPT" next to any IAF that is in direct alignment with the FAF.
dhc8fo said:5-4-9
You will not find "NoPT" next to any IAF that is in direct alignment with the FAF. That isn't how it works.
midlifeflyer said:~~~ Edit~~~
Ah. I'm wrong. The PT for the VOR =14= is needed. The approach assumes you don't have DME, so, even coming in on the feeder, the PT is there for altitude loss.
midlifeflyer said:Not necessarily. Get past the obvious nonsense of saying things like to support the argument that if the term NoPT is =not= used the procedure turn is still not required.
midlifeflyer said:dhc's point that is an interesting point.
[/QUOTE}
dhc's point is very worrying since the way he phrased his statement he appears to believe that NoPT is associated with an IAF, whereas it is actually associated with a route - a distinct difference.
midlifeflyer said:It's pretty obvious that it =shouldn't= be needed.
I've never argued, and I don't think you have, that going straight in isn't perfectly safe. The question is - is it legal - and I don't believe it is based on the FAA's publications and the the letters of interpretation.
There are lots of things in aviation that are legal but not safe, and plety of things that are safe but not legal. In the end you have to strive to find things that are both legal and safe - but it's folly to believe they are the same thing.
ackattacker said:It's certainly true that you will find plenty of IAF's lined up with the FAF that don't have "NoPT". But do they also have procedure turns? If they don't, then of course you go straight in... if they DO, then the PT is required. I'm hoping someone else can come with more examples of approach charts like those out here. Otherwise, it does seem to be anomalous.
Of course, you probably noticed that I ended up arguing with myself in that post. I should have deleted it instead of editing it.CFIse said:Wow - you are obviously in need of an argument since you're now arguing with a person who supports your position.
Thanks. Between the two of us we'll at least get the parameters of the argument down.nosehair said:I'll chime in here on this one. Midlife is familiar with my take on the "when is a PT required" question. Everyone is missing the essential ingrediant. The AIM explains and describes a Procedure Turn with the opening statement: "A procedure turn is the maneuver prescribed when it is necessary to perform a course reversal to establish the aircraft inbound on an intermediate or final approach course." Look at that statement. Don't read anymore(yet).
...and likewise, you can't just read the second sentence, "a procedure turn is required", by itself, either. They both go together. Like this, in human speak: "If a course reversal (or alignment) is required, the direction of the turn is depicted by the barbed arrow, or holding pattern, or other bold line as depicted". When the approach chart shows "NoPT", that means we (the TERPS guys) have determined that the course is closely aligned enough that a course reversal is and should not be required, so we will depict it as such so that you must request a PT if you need one. 91.175(j) and the AIM language on NoPT all spell out conditions under which you SHALL NOT make a PT except when requested. It DOES NOT say "EXCEPT under these conditions, YOU SHALL ALWAYS make a PT even when you are aligned."midlifeflyer said:(1) a definition of a phrase is not a legal statement of it's effect on our conduct, so you can't "just stop there,"
DC8 Flyer said:http://www.naco.faa.gov/d-tpp/0506/05187I35L.PDF
Coming from the south east or sout west I could easily Vector my self to this ILS. HISER is a Compass Locator and IGFK has DME. I still have to do the PT though, if Im not being radar vectored.
ackattacker said:I don't think it's quite the same thing. This approach doesn't have a seperate IAF and FAF. Also, at a bare minimum it only required an ILS and an ADF, so the approach has to assume that you don't have DME and therefore cannot safely descend until you cross the IAF "outbound". GPS approaches don't have to make that assumption.
I thinknosehair said:Mark, I'm not making this up, I'm reading *in context*, all the language I can find on the subject and cannot find a definitive statement that says you must do a PT even when you don't need to make a course reversal. The legal opinion does not answer that question.
midlifeflyer said:show me one thing from the FAA that suggests that a PT is always optional -
It's still in the Glossary:puddlejumper said:I seem to remember the ATC-Pilot Glossary including the phrase: "Cleared For The Straight-In Approach" Is that still the case Mark?
midlifeflyer said:You can play with "when necessary" all you want, but it says that a PT is "prescribed" when necessary; it doesn't say "a PT is flown when the pilot decides it's necessary."
No.nosehair said:There! There it is! "A PT is prescribed when necessary." Who do you think is responsible for determining "when necessary"? Not the pilot?
Geronimo4497 said:Check out the GPS 27 into PDK. I shot this this past weekend and when I asked the ATL controller if anyone ever does the procedure turn he replied 'NO'. Why in the world would they draw in a procedure turn when there is a 24 radar equipped approach control not more than 20 miles away? This is not just a VOR overlay, either. The VOR course is 277 inbound, vs the GPS inbound course of 268.
Beats me, any thoughts?
But you shot the Vis approach into PDK anyway so what's the difference? And yes you can get vectored onto a GPS approach. AIM1-1-19 O 6Geronimo4497 said:Check out the GPS 27 into PDK. I shot this this past weekend and when I asked the ATL controller if anyone ever does the procedure turn he replied 'NO'. Why in the world would they draw in a procedure turn when there is a 24 radar equipped approach control not more than 20 miles away? This is not just a VOR overlay, either. The VOR course is 277 inbound, vs the GPS inbound course of 268.
