indianboy7 said:Ya, I think the media has absolutely no idea that airplanes have brakes too.....I heard "they hit the thrust reversers pretty hard" so many times the other night, I ended up puking.........who knows though....that coulda been the problem....imp:
I hear you hoss, not getting "pushed" is one of the reasons I like working where I work...It's definitely not for the SEL Turbine PIC time logging.TurboS7 said:Landing data two engines is based on no reverse, takeoff data the same. The only time reverse comes into play is landing with one engine, and stopping with a failure prior to V1. The bottom line is that MDW is way too short for Part 121 operations in any kind of severe or abnormal weather. The airport managers and airline officals are full of BS. The operate there because it is cheap, cheap, cheap and Chicago Airport Authority like the money. They push the airplanes and the pilots then fault the pilots because we are not perfect. This industry stinks, and the pilots are the ones that take the windfall......and we get paid too much....SURE>>.
14CFR 25.125(b)3
(3) Means other than wheel brakes may be used if that means—
(i) Is safe and reliable;
(ii) Is used so that consistent results can be expected in service; and
(iii) Is such that exceptional skill is not required to control the airplane.
14CFR 25.125(f)
(f) If any device is used that depends on the operation of any engine, and if the landing distance would be noticeably increased when a landing is made with that engine inoperative, the landing distance must be determined with that engine inoperative unless the use of compensating means will result in a landing distance not more than that with each engine operating.
(paragraph e is directional stability, exceptional skill, etc.)14CFR 25.109(f)
The effects of available reverse thrust—
(1) Shall not be included as an additional means of deceleration when determining the accelerate-stop distance on a dry runway; and
(2) May be included as an additional means of deceleration using recommended reverse thrust procedures when determining the accelerate-stop distance on a wet runway, provided the requirements of paragraph (e) of this section are met.
Rally said:Reversers or not should'nt the -700 be able to stop in that length of runway with that amount of snow UNLESS they were too fast or too long?
EagleRJ said:I think you have it backwards. Including reverse thrust is allowable under Part 25 certification, except that single-engine operations must be accounted for. Aircraft manufacturers can and do use reverse along with normal braking to determine landing distance.
Accelerate/stop distances are determined without reverse thrust on a dry runway, and with reverse thrust on a wet runway.
I do agree that while the runway at Midway meets the letter of the law, it's dangerous to fly 121 carriers out of there without a sufficient overrun. We have too many airports operating under waivers these days, and the FAA needs to be more stingy in allowing them. MDW should only be allowed to have a waiver for reduced overrun if an EMAS system is installed on each runway approved for 121 operations.
Once again, hindsight is 20/20.
Hmmm, I don't see a subpart to 121 titled "Operating Requirements: Domestic, Flag and Supplemental Operations."GVFlyer said:Nice post concerning required aircraft operating characteristics, but unless you're an experimental test pilot participating in an aircraft certification program, you're reading the wrong regulation. Note the the title: Part 25: AIRWORTHINESS STANDARDS: TRANSPORT CATEGORY AIRPLANES. You need to be reading Part 121: Operating Requirements: Domestic, Flag and Supplemental Operations.
I included the hyperlink so you can read Section 25.1 Applicability. Part 25 has nothing to do with operating the aircraft after it has earned it's Airworthiness Certificate unless you are working on an Supplemental Type Certificate.
GV
A Squared said:Hmmm, I don't see a subpart to 121 titled "Operating Requirements: Domestic, Flag and Supplemental Operations."
You got a specific reference for that?
satpak77 said:That is the name of the Part 121 section
KeroseneSnorter said:I too have never flown a jet that used thrust reversers as part of the landing data. Everything is based on brakes and lift killing devices (Spoilers etc.)
Dunno about the ERJ but nothing I ever flew in the corporate or airline world is based on thrust reversers for landing.
This is an awesome statement and I could not agree with you more. Its so true. Pilots are pushed and then blamed when the outcome isn't perfect. Its total BS.......and yes, the pay sucks too. Its no doubt we dont do it for the money. If flying wasn't fun the aviation world would be screwed.TurboS7 said:Landing data two engines is based on no reverse, takeoff data the same. The only time reverse comes into play is landing with one engine, and stopping with a failure prior to V1. The bottom line is that MDW is way too short for Part 121 operations in any kind of severe or abnormal weather. The airport managers and airline officals are full of BS. The operate there because it is cheap, cheap, cheap and Chicago Airport Authority like the money. They push the airplanes and the pilots then fault the pilots because we are not perfect. This industry stinks, and the pilots are the ones that take the windfall......and we get paid too much....SURE>>.
Guitar rocker said:Quit speculating Rally! Again, you are making an assumption that perhaps they landed too far down or too fast. All indications point at the fact that they were right where they needed to be. It's unprofessional to make such assumptions and second guess anyone here. One last thing Rally, I hope that you do understand that this could have happened to anyone of us!
It was reported that the aircraft picked up a tailwind on final approach. Not sure how much that will factor into the outcome but it was an issue.Rally said:Reversers or not should'nt the -700 be able to stop in that length of runway with that amount of snow UNLESS they were too fast or too long?
GV
satpak77 said:while not official POH guidance, nonetheless....
http://www.b737.org.uk/limitations.htm
"No tailwind component allowed on contaminated runways"
this is independent of any TR problems or other stuff
don't know if this applies to the 737-700....came across it when I was reading up on 737 performance data
TR4A said:This is posted on that site:
"Note: Not all limitations given here are AFM"
9GClub said:So we're tossing out reverser data for a dry runway but including it for a wet one huh? Why do we wanna add the reverser variable to an already full wet runway equation? This is SOP?
So these guys are expected to bleed off 120KT on a [6522'-1000'=] 5522' contaminated runway with no EMAS, a tailwind, and a better-be-functioning TR setup. No thanks.
