Give me carbed or give me death!
gkrangers
college = debt
Seriously, why are these god damn fuel injected 172s such a bitch to start sometimes?
Today, started right up. A few hours later, starting it again, took me over 30 minutes and 10+ tries.
Whhhhhyyyyyyyyy?
*goes to corner to cry*
Hot start; try mixture idle cutoff, throttle full, crank til it kicks, then, mixture rich and throttle a thousand or so. I think thats right.
That's actually the flooded start procedure, but a lot of times that will work if you get too enthusiastic trying to start a vapor-locked engine.
I've never flown a FI Skyhawk, but I usually had luck starting the bigger FI engines by using as much prime as I could get away with to get some cool fuel in the lines. If I went too far and flooded it, the vapor lock was cleared, so I just did a flooded start and it usually fired right up.
Don't flood it on purpose- that's bad operating procedure and will cause accelerated wear- but if that's where you wind up, you can still get the engine started if you know what's happened.
If it is really hot, sometimes I leave the fuel pump on low, mixture full lean and throttle to full. Crank the engine, when it catches, bring the throttle back, mixture in and fuel pump off.
Sorry that it took you ten tries. It took me almost that long to get it right one day, I sure felt like a jacka$$.
Jack
(kind of ironic huh?)
Jack
That always worked for me
viper548 said:
sounds like you're doing something wrong if it's taking you 10 tries to get rid of vapor lock
its a damn cessna...i tried everything several times.
finally got it to start going with no fuel pump, mixture rich, throttle open a touch, I think...can't even remember which configuration got it too work.
Normal: throttle open 1/4", mixture rich, pump on for a few seconds, pump off, mixture idle cutoff, ignition...advance mixture when it starts.
hot: throttle full, mixture idle cutoff, start.
They have been giving me issues lately at times....last spring I had no problems whatsoever with the SPs.
And the term vapor lock is thrown around a lot, but what is it exactly and how do we get rid of it ?
I know I'm showing my inexperience here...but damn, I've never had to try more than 3 or 4 starts till tonight.
The fuel injector is on top of the engine. When the engine is run and is sitting there after shutdown, the heat goes up. The fuel in the injector "lines" vaporizes because of the heat. You need to send some "cool" fuel into the lines so you have liquid in there.
Your hot start listed above sounds like a flooded start.
For a normal hot start (engine was running recently), try doing the normal start only without the priming steps. That's the procedure for the 172R (IIRC) and it seemed to work well.
If it doesn't start, just let it cool for 30 minutes (I know the delay sucks but...) and it should start fine for ya.
How'd the DUATS thing go?
-mini
-mini
On our Cessna 320, vapor lock was such a problem that I would pop the side panels to the cowling open when I would stop for a while. There were long side panels on both sides of the cowling that could be opened, so no matter what direction the wind was blowing with relation to the plane, you were going to have some cross ventilation regardless. That helped a lot, especially since that was turbocharged.
It seems like there's a knack to getting the different ones started, once you get it down you'll quit wearing out the starter and your ego. I'd probably have to re learn it all over again myself now that I haven't flown injected for quite a few years.
That would have to make it twice as sucky...I mean...take a normal IO-360. They can be a pain, but managable. Take a TSIO-360 and...man...wouldn't that just double or tripple the heat?
Hot starts in a turbo have to be a sh!tty deal.
Was that pretty much SOP to open up the cowling or just something you picked up on?
-mini
-mini
It was just an idea I had after vapor lock was explained to me and I looked at the cowling and saw the panels.
Also, we incorporated this other technique that seemed to work. Keep the mixtures off and run the boost pumps on high for about 10 seconds. Supposedly, that allowed the fuel to purge the system up to the bendix valve, with the vaporized fuel being returned to the mains. You might want to check with a mechanic first, because it's been a while and your fuel system may be different.
It doesn’t matter what starting procedure you use if the mags are out of time and the impulse couplings have gone bad.
What kind of mag drop do you get? To the limit? How much difference when switching between L & R?
I know this is bad to do but carefully pull the prop through very slowly and listen for the click from within the cowling. There should be 1 click for each rotation of the prop. If you hear 2 clicks, then the mags are out of time and should be checked by a mechanic.
The click is your impulse coupling (located inside the mags) which retards the ignition so the plugs fire at Top Dead Center (TDC) instead of 20-25 degrees prior to TDC. They also increase the voltage to help aid starting the engine.
One of our older carbureted 172's had this problem and was a beeotch to start. Some engines dont have impulse couplings at all (C65 on the J3 for example) and rely strictly on properly timed mags for easy starting (which is nice being YOU are the starter lol).
Vapor lock, a flooded engine, and/or bad timing on the mags will ruin your day. Hope this helps.
au
Impulse coupling
Correct me if I am in error, but don't most engines only have one impulse coupling and only utilize one mag for start? When the key is in the start position it grounds out one of the mags (the one that does not have the impulse coupling). Also, I assume that the impulse coupling would click four times for every rotation of the propeller, one for each igntion event/power stroke.
As far as the mag timing goes, the mags are not timed to the impluse couplings, they are timed to the point opening. You'll get an impulse click per prop blade rotation on a four banger. Some aircraft engines have two impulse couplings per engine, mine for example does (TCM IO-360) but most Lycomings don't.
When I was working on the Rockwell Commanders, there was a service bulletin out to remove a bus bar from the back of the mag switch that grounds the right mag when you go to the start postion. What this bar did was to ground the right mag during the start (key to the start postition), so with the bar removed, you were getting two start sparks, one just after top dead center and the other at the normal crank position.
The impulse coupling not only retards the spark, but it also speeds up the rotating magnet in the mag to build a higher voltage. The magneto makes its own electricity, but it needs about 300 rpm to do so. The engine may not make that while starting, so the impluse makes up for the low speed.
tried starting it 10 times? what'd your battery juice look like after that? next time, give the starter a rest and just let it cool down for, as mentioned before, 30 minutes or so. i've found if you just let them sit a bit longer there are no problems.
I let the starter rest in between...at one point I had enough, and just chilled watching the planes (and a nice Falcon jet) for 20-30 minutes....took another 2-3 attempts after that break, but it started.
Battery was ok.
So I guess the idea is to just sit and wait if you are vapor locked ?
91W never gives me any problems! I'm gonna start flying that again. :D
-mini
I don't think I have filed since, but I'm sure I'll have no problem.
Mags were dropping ~100 RPM, both of them.
I attribute it to vapor lock and me bein a dumbass.
Vapor lock is a reality of fuel injected engines. When I was instructing we used to purposely flood the engines if it was going to be a hot start. Put the throttle and mixture forward and run the boost pump until fuel is dumped overboard (out the bottom right side of the cowling), then pretty much do a normal start with a little extra throttle. With enough practice you will be able to get a good start every time. I always took pride in having a nice start where the engine stabilizes just above idle. You know you can tell an owner from a renter by how he starts an engine. The owner always starts it on the first or second time with minimal engine run-up during start, the renter takes 3 or more times and runs the engine over 1500 rpm before getting things under control.:D Of course I've never been an owner but I can pretend.
That said it soulc be something else. Has you always had a hard time starting this particular engine or has it become more difficult since the weather has changed? How does the engine idle after start? How does it idle when brought from running speed to idle (especially if brought to idle quickly by a ham fisted student)? The reason I ask is because the flight school I used to work for had trouble with it's engines any time the weather would change (warm to cold was the worst if memory serves me, which it may not). They even instituted a policy that we couldn't bring the engine all the way to idle during stalls, after one Cessna experienced an engine failure during a stall. They were able to get the engine restarted but they were about 500 feet above the ground with no landing spot below before it did. Anyway, when engines started running rough we wrote it up and the mechanics would adjust the idle mixture and the problem was solved.
Disclaimer: I am not a mechanic, or an expert of anything, any advice you take from me take at your own risk. Always follow your airplanes AFM.
I fly a different SP almost every time...usually no problem, maybe 3 starts on a rare occasion. This one was the exception for me.
Its Florida...the weather doesn't change. :D
Idle was fine...runup was fine...ran smooth.
The fuel injected Cessnas can be a pain if you dont know how to start them hot. I just do what a few of you have said: Mixture full lean, Throttle full forward, starter engaged, mixture rich and throttle back as soon as it turns over. It works every time. I think that Cessna calls for something different but I cant remember, its been a while since Ive flown one.
See my profile, "still learning" lol. I talked to our mechanic today and he cleared me up on these two things. One of our planes has impulse couplings on both of the mags while the rest only have one.
Thanks for correcting me,
au
