Look at the cockpit windows, then look at the wingtips.WW24dude said:..I can't keep them straight. Can someone post the differences in appearance and/or pics?
I haven't flown any of em but here's my shot...WW24dude said:..I can't keep them straight. Can someone post the differences in appearance and/or pics?
suen1843 said:Look at the cockpit windows, then look at the wingtips.
6 windows (2 side, 2 little "dv", two forward) = GII
4 windows (only side and forward) = GIII
Now, the fun part. If it has been identified as a GII, look at the wingtips. No winglets, then it's a straight GII. Winglets, with real sharp upturn at the root of the winglet, it's a GIIB (the best of the bunch). If the winglets have a real smooth, graceful upturn at the root, it's a GIISP..an aftermarket conversion. Occasionally you will see one with tip tanks...a GIIT (not many around).
There are several other visual cues, but the above mention are the quickest and easiest.
Bro .....no offenceWW24dude said:..I can't keep them straight. Can someone post the differences in appearance and/or pics?
You make it to easy bro!....in a word ......VSCF BabyTIS said:This is all basically correct information.
Crash-Proof has a few errors.
Here's the correct stuff:
G-II - no winglets, six flat-plate cockpit windows
G-IIB - GII with a retrofitted G-III wing - adds substantial fuel and efficiency to the G-II
G-IISP - G-II with an STC for blended winglets by Aviation Partners. They claim increased efficiency benefits but no one really seems to be able to agree how much. Another HUGE difference between the G-IIB and the G-IISP is that when damaged, one or both winglets on a GIIB can be removed and the aircraft returned to service without it/them - per the CDL. This cannot be done on the G-IISP.
G-III - Looks a lot like a G-II/IIB but has four-panel curved wrap around windscreens. Has the same five windows down the side as a G-II/IIB.
G-IV - Six windows down the side and big high-bypass ratio trubofan RR-Tays instead of the little pinner Speys.
Now for the big trivia question: Anyone know how to tell an AC powered G-III from a DC powered G-III?
TIS
Otter said:Tis,
As to your trivia question on the AC vs DC question. The tell tale second larger scoop on the engine nacelle for generator cooling has to be the single easiest, after that ...now Im digging, I believe that the AC version has a different APU exhaust plate, due to its ability to be used in flight as opposed to the DC version.
