Slice121 said:I believe to renew an expired cert you can go thru a DPE. You can also add on an instructor rating that will rehack your clock.
nosehair said:1975?...Welcome back! You have one of the old CFI certificates which just has "Airplane", which meant you could instruct airplane instruments if you were instrument rated on your commercial, and multi engine if you were multi on your commercial....wait, maybe that changed in '74....well, anyway, you will need to refresh youself in little airplanes, and take a CFI Re-Instatement ride, which, in your case will probably be almost as extensive as the initial, but, of course, you know how that can vary. If you have one of the old certificates, you will have to take 3 rides: CFI-Airplane Single Engine, Multi Engine, and Instrument. If you took seperate rides back then, and your old CFI certificate has those words, "Single engine", "Multi engine", "Instrument-Airplane", then you will only need to take one ride which will renew all three.
My best advice, besides getting a good seasoned instructor, is to get a current copy of the Flight Instructor PTS, and also the Private and Commercial PTS, and use them to brush up on all reference material indicated in those PTS's.
xdays said:Slice, thanks for the response. Where did you fly the Viper? My son is a Flight Commander in the 55FS at Shaw.
xdays said:My CFI cert has been expired for quite a while (1975) and after a long airline career I'd like to do some Instructing. Since I've been out of the loop for so long what suggestions would y'all have for me to get current again? Thanks for the help.
x
