Maybe someone can clear up this question I have. Why exactly do generators have altitude limitations? I've been told that it has to do with the "normal" air gap between the brushes and commutator, which has a higher resistance because of the decreased air density, and therefore increases the excitation current needed (which increases temperature, which is the ultimate limiting factor). But why is there an air gap in the first place? I can't imagine that any gap between the commutator and brush would be acceptable, but they're saying that it's there AND normal. In case you're wondering, the particular aircraft we're talking about is a Falcon 2000EX, which has an APU altitude limitation of 35k.
