Last night went for a flight which was the first after upgrading my Garmin G3X Touch from 9.14 to 9.22. The update appeared normal and for the first time as noted in a recent post I made I watched the audio panel controls show updating. I have the GMA 245R in my CubCrafters FX-3 with IFR panel. I typically get an audible from ForeFlight approaching the runway and I heard nothing. I figured maybe something was set incorrectly as the phone audio depends on the intercom option for music vs. bluetooth input. Later in the flight I started checking into this and sure enough SiriusXM wasn't playing either. My volume levels were reset which I noticed on the ground. I had to turn on the "music" option, and fiddle with various settings to get everything back the way I like it.
So FYI...after the update if you see that your intercom was updated do some ground checks as desired to ensure the intercom panel and tabs are all configured as desired.
