G200/Galaxy brakes-WTF?
Here's my theory, for what it's worth... The brakes are pretty much the same as the Challenger (which do a great job at 12,000 lbs heavier than the 200). The problem is there is only 1 hydraulic system taking care of the brakes and the deployment of the right thrust reverser. With the reversers locked out until the nose wheel touches down + 3 seconds, you are usually on the brakes first. Once the buckets start to deploy, there is an additional demand on the right hydraulic system and just that small, momentary pressure change is enough to start the duck-walk inherited from the Astra. Want to test that theory? Next time you have the right conditions, don't deploy the reversers and use only brakes to stop. Bet she won't even think about duck-walking. Or with a strong headwind, use the reversers only (even idle reverse) until you are slowed to a normal taxi speed.
After extending the gear, pump the brakes 3x.
Never noticed any difference with that. My personal theory is glazing. Thhe brakes are too big for the airplane, and as a result never get hot enough to keep them from glazing. Except for that precise moment when they are used at 100+knots, but then we ease off of them almost immediately. Not the way carbon brakes were intended to be used, to my understanding.
But then again, I'm usually full of crap.
Glazing is do to long application of brakes, making them too hot. Which would mean big brakes are less likely to glaze. Not sure how this gets reversed on airplanes or carbon brakes but I'm all ears.
My understanding was that they would glaze if they didn't get hot enough. I was once told by a D.O. That if you were going to use carbon brakes then light the suckers up because small light applications were harder on them than heavy use. The reason being that they wold glaze and become less effective causing more wear as they 'de-glazed' and the brakes would bite. I'm not claiming to be an expert, but I've never been able to prove the other two theories presented though experimentation.
P.S. Take it easy.
My ability to explain glazing would be uninterpretable to the layperson due to my advanced degrees in metallurgy, chemistry and training - or I am full of crap but still have an idea of what brake glazing is and don't want to F it up. If you think anything but the latter, you probably think that glazing happens from brakes not getting hot enough... I will offer that I am just having fun svcta - so take it easy... :) BTW - I don't know that my examples - others writings are scientifically accurate, but they demonstrate what I believe to be correct.
After you have installed the new pads, it is a good idea to break them in (unless the pads are the "fully cured" type that do not require an initial break-in period). Not breaking in a new set of pads increases your risk of pad glazing and brake noise. A driver can glaze and ruin a new set of pads if he fails to go easy on the brakes for the first 200 miles. If he overheats the brakes by mashing down on the brake pedal at every stop light, he can cook the resin in the pads before it can cure and glaze the pads.
Disk brake pads do sometimes develop a glaze which causes squeaking, etc. IIRC, heat can sometimes form a glaze on the surface of ceramic brake pads. In layman's terms, the glaze is like a layer of glass, formed out of the ceramic material in the pad.
At the end of the day, none of this matters. The G200's brakes suck. Whether it's over braked, under braked, or just generally has a poorly designed, poorly implemented hydraulic system (my theory), there isn't much you can do about it except trade it in on something else...
I have no idea if the brakes in a G-200 ae the same compound found on a typical Dodge, but ours were quite noisy. On both of ours airplanes as I recall. Funny how nobody, even the fine folks at Gulfstream, could explain why the brakes on that airplane are so dicey.
Either way, tt is right. They suck.
The ever-present dangers of internet discussion. No sweat!
Okay, this conversation lead me to our DOM, who is one of those very smart people when it comes to stuff like this. And he even showed me a video that was quite informative.
First of all, carbon brakes as installed on airplanes do not have ceramic in them. So, they don't "glaze" in the way that auto brakes do (which was cited in this conversation).
When carbon brakes are used, carbon bits are worn off of the brake components and create friction between each other (rotors and stators). At first these carbon particles are very big and consequently cause A LOT of wear at lower temperatures. As the temperature in the brakes increases these particles get smaller and smaller and ultimately become almost like a film between the rotors and stators. As the brakes are heated toward 150 deg C the level of wear increases rapidly, until the 150 degree point is crossed, at which point the wear rate decreases to its lowest level. So the hotter they are, the lower the rate of brake wear.
The point being that when you use a set of carbon brakes (on airplanes) you want to get them as hot as possible as quickly as possible. And once they're hot, keep them that way. Long brake applications during taxi are still taboo, as we agreed. The preference being short bursts of braking from around 20 knots to a near stop. Let it speed up, then slow it down, never just drag them.
The manufacturer even suggested that turboprop operators use the brakes instead of reversing the props when possible, for example. The main thrust of the thing being this: If you're going to use the brakes, then light those suckers up. Don't be gentle with them. They must get hot to work their best.
Found the information below on the Boeing site at the bottom of the page: svcta - is that video accessible somewhere on the Internet?
Because the wear mechanisms are different between carbon and steel brakes, different taxi braking techniques are recommended for carbon brakes in order to maximize brake life.
Steel brake wear is directly proportional to the kinetic energy absorbed by the brakes. Maximum steel brake life can be achieved during taxi by using a large number of small, light brake applications, allowing some time for brake cooling between applications. High airplane gross weights and high brake application speeds tend to reduce steel brake life because they require the brakes to absorb a large amount of kinetic energy.
Carbon brake wear is primarily dependent on the total number of brake applications — one firm brake application causes less wear than several light applications. Maximum carbon brake life can be achieved during taxi by using a small number of long, moderately firm brake applications instead of numerous light brake applications. This can be achieved by allowing taxi speed to increase from below target speed to above target speed, then using a single firm brake application to reduce speed below the target and repeating if required, rather than maintaining a constant taxi speed using numerous brake applications. Carbon brake wear is much less sensitive to airplane weight and speed than steel brake wear.
These recommendations are intended as general taxi guidelines only. Safety and passenger comfort should remain the primary considerations.
It is, i'll find the link. Realize that what you posted is concurrent with what I said regarding taxi technique. Slow the airplane down with one brake action from a relatively fast taxi speed, and then let the speed build back up. Don't drag the brakes, or slow down and speed up over and over and over. We're in agreement on that.
Edit: the video in question:
http://www.google.com/url?sa=t&rct=...1N2jBw&usg=AFQjCNGZqw0KyF2mUVxJC6XCw_3bQIoiTw
Interesting. I guess in ceramic brakes, the "glazing" is actually a good thing?
This is one of those things that Embry Riddle teaches you but doesn't teach you the WHY or HOW it works that way. I always knew carbon brakes wore quicker when cold and when used sparingly, but it didn't make any sense to me. Thanks for the explanation.
