G-IV Fuel Burn
What's the max fuel? What's a typical min landing fuel #? How many hours endurance?
Could you make it to Buenos Aires from Southern FL?
If I remember correctly max fuel is 29.5K, we used 5-6K typical landing fuel, and I've done 8+30 at .80 and landed with 4500.
As a rule of thumb, I found that the first two hours you burn 8000 if heavy and 7000 if light then I use 3000 for each additional hour. Generally I use 5000 as minimum planned landing fuel, depending on the weather. Have landed with less than that a few times. Keep in mind that with full fuel, you will need about five hours to get down to landing weight.
8000 pounds are you NUTS!
Here are REAL world numbers.
4100 - 3100 - 3100 - 2800 - 2800 - 2500
For normal 2-4 hr trips are real goog gouge is 3000 perhour PLUS 1000 more for the first hour. Normal Landing 3-5000 .
BTW the GV fuel burns are ABOUT the same but go on and on and on.. :)
These are the numbers I use for the G-IVSP and the GV. The G450 and G500/G550 will do better.
G-IVSP M0.80 / M0.85...................GV M0.80 / M0.85
Time....09:16 / 06:30.........................14:33 / 12.00
.................................Fuel Burns........................
Hr1.......4000....4800............................4100....4400
...2.......3100....4600............................3100....3900
...3.......3100....4200............................3000....3700
...4.......2800....3700............................2900....3500
...5.......2800....3500............................2700....3400
...6.......2500....1250(6:32)....................2600....3100
...7.......2500.......................................2600....3100
...8.......2500.......................................2400....2800
...9.......2500.......................................2300....2800
...9:16....294.........................................................
...10....................................................2200....2600
...11....................................................2200....2600
...12....................................................2200....2100
...13....................................................2200...........
...14....................................................2200............
14:33....................................................822.............
GV
Fuel Fool
I too always rough in flight time multiplied by 3 plus 1000 pounds. Then compare against the FMS and Flight Plan.
Always worked pretty good.
TCA
Maximum fuel is 29,500 lbs, however, if you can get more fuel than that onboard such action is approved. I've loaded 30,500 lbs onboard on a cold day at Edmonton, Alberta.
I've flown the G-IVSP 9:20. The guarantee is for 9:16. The longest flight I know of was 10:20 between LSGG and DAL which was flown by one of the Demo guys at Gulfstream (who now works for Oprah).
MIA - SAEZ direct is 3828 nm - 8:20.
It's 3989 nm and 8:41 if you chose to route over Manaus (SBEG).
If you select this routing on the way back, Aruba (TNCA) falls out under the course if you encounter adverse winds.
Keep in mind that the G450 will fly 400 nm farther than the G-IVSP.
GV
I have done Miami - Milan Nonstop. 10 hours flat at M.76. We started at FL370, crossing was at FL390 and only made it up to FL430 before it was time to come down. We landed with 3000 lbs of fuel. VFR day. Part91 of course.
Do any of you G-IV drivers have any real world operating cost for the IV. Company has sold the G-III and is considering a G-IV. Any help is appreciated.
Thanks.
"Direct Operating Cost - Gulfstream Products (Conklin and de Decker)
G-IV - $3,151 / hour
G-IVSP - $2,997 / hour
G300 - $2,853 / hour
G400 - $2,855 / hour
G350 - $2,691 / hour
G450 - $2,706 / hour
GV - $2,936 / hour
G500 - $2,625 / hour
G550 - $2,642 / hour
GV
