As a rule of thumb, I found that the first two hours you burn 8000 if heavy and 7000 if light then I use 3000 for each additional hour. Generally I use 5000 as minimum planned landing fuel, depending on the weather. Have landed with less than that a few times. Keep in mind that with full fuel, you will need about five hours to get down to landing weight.
Too hard for me. I've used 3k per hour plus 1K. Always worked fine. For very long trips I used CFP
