Shock cooling?
An exerpt:
Shock Cooling: Myth or Reality?
Powerplant management guru Kas Thomas of TBO ADVISOR examines the physics and metallurgy of "shock cooling" and concludes that, contrary to the conventional wisdom, it is not a major contributor to cylinder head cracking.
This article first appeared in the March 1996 issue of TBO ADVISOR and appears here by permission. The article is Copyright 1996 by Kas Thomas.
By Kas Thomas (
[email protected])
Photo: FredWeick made many contributions to our knowledge of engine cooling.
Not long ago, a writer for a major aviation publication called to ask my opinion(s) on the subject of shock cooling. It turns out the caller had already written his article, but he wanted to run some ideas by me to make sure he wasn't missing something. Since I get a lot of calls on this subject, I had some ready answers for him. Not necessarily correct answers--just ready answers.
I don't think anybody has provably correct answers to questions involving shock cooling of aircraft engines. To my way of thinking, there is no scientific proof that shock cooling plays a significant role in cylinder damage in aviation. "Scientific proof" is perhaps a poor choice of words. What I'm simply trying to say is, the hard evidence is scanty. I know of no fleet studies on this subject. I know of no pilot who can say "I went up and did this and this and this to the engine, and then when I landed I found these cracks that weren't there before."
Still, it's hard to argue with common sense, and common sense says that if you thermal-cycle a piece of cast aluminum (especially while beating on it!) you just might induce it to crack. Pilots can perhaps be forgiven for harboring a strong gut feeling that yanking the throttle back is a good way to bring on cylinder cracking. Certainly, many millions of dollars' worth of spoiler kits and CHT systems have been sold to pilots on this basis over the years.
My own gut tells me that shock cooling--while bound to induce dimensional changes in the engine--is not a great contributor to cylinder cracking. We know it induces dimensional changes, because (for example) valve sticking has been induced in some engines by sudden power reductions. (A Lycoming Flyer article once stated: "Engineering tests have demonstrated that valves will stick when a large amount of very cold air is directed over an engine which has been quickly throttled back after operating at normal running temperatures." See 101 Ways to Extend the Life of Your Engine, page 96.) But it's a big jump to go from that to saying you can make a cylinder head crack just by pulling the throttle back too quickly.
To my knowledge, Bob Hoover has not experienced any problem with cylinder-head cracking on his Shrike, despite his rather odd predisposition to feather both engines while in a redline dive. (Maybe this is what FAA meant by "cognitive defect"? Just kidding.)
Besides which, I think any careful examination of the concept of "cooling" (as it applies to current aircraft engines) will leave one virtually empty-handed, because I think it could be argued that cooling fins on aircraft cylinders are of mainly ornamental value. I suspect that you could hacksaw much of the finnage off, say, a TSIO-520's cylinders and not affect inflight CHT readings by very much. As it happens, this is exactly what Continental did when it created the "lightweight" Crusader engine--the TSIO-520-AE used in the Cessna T303. The cooling fins on this engine are fewer in number, and about half the size of, those on a standard TSIO-520. And yet, CHTs in the T303 are remarkably cool. (One of our readers, in fact, reports a problem in getting CHTs to stay in the green; see this month's "Questions and Answers," page 26.)
Various investigators have done "energy balance sheets" on aircraft engines, and the result is always the same: Only about 12% of the heat energy generated in combustion goes out an "air-cooled" engine's cooling fins. The biggest fraction (around 44%) goes right out the exhaust pipe, of course. Another 8% or so finds its way into the oil--which is quite interesting, because it means the oil plays almost as big a role in cooling your engine as air does. The remaining energy shows up as work at the crankshaft.
Throttle placement doesn't have nearly as direct an effect on CHT as you might think. Back in 1983, there was an SAE paper (No. 830718) by three Texas A&M researchers who tried to correlate OAT (outside air temp), CHT (cylinder head temp), EGT (exhaust gas temp), power settings, air density, and cowl pressure drop in Lycoming TIO-540 engines. Their work was partly based on the NACA Cooling Correlation (NACA Report No. 683, published in 1940), which in turn was based on pioneering work done by Fred Weick in the late 1920s. The Texas A&M group merely extended NACA's approach, verifying their results with inflight measurements taken on a Piper Turbo Aztec and a Rockwell 700. One of their key findings was that the difference between CHT and OAT is proportional to the difference between EGT and CHT, which is (if you dwell on it long enough) intuitive, since the difference between the average exhaust temperature and CHT is what "drives" CHT changes to begin with. (If this isn't intuitive to you, you may want to go back and re-read Fourier's classic Analytic Theory of Heat.) This portion of the group's findings might be summarized by saying that the stored heat of the cylinder head is proportional to the input heat, represented by EGT minus CHT.
But there are two aspects to cylinder cooling. One is the "supply side" aspect (which we have just been taking about--all this business about EGT minus CHT), while the other is the taking-away of heat, or "cooling" aspect. The Texas A&M group accounted for this too. They found that the stored heat is proportional to the input heat--proportional, that is, by a factor y. The factor y, in turn, is made up of engine power raised to a certain exponent, divided by cooling airflow delta-p raised to a certain exponent. The engine-power exponent is fractional; for the Rockwell 700 it turns out to be 0.33. (It varies from plane to plane depending, apparently, on peculiarities of engine installation and operating envelope.) The air-cooling delta-p exponent is also fractional (0.29). In plain English: CHT depends on the cube root of engine power, divided by the cube root (roughly) of the cooling-airflow pressure drop.
contd.
