Fuel Consumption @ Takeoff Power
25,000 lbs per hour per engine, so that makes +/-100,000 pounds per hour at takeoff thrust. I guess if we use reduced thrust, it might be a little less. But we're hauling a lot...
iaflyer
Sorry about the late request, I ment to add it to the original post. If you could add the equipment that would be greatly appreciated ;)
iaflyer, I am guessing by your avitar, you're on the 47?
1300-2000 in the Dash 8 depending on the model.
777_Jackpot said:
iaflyer, I am guessing by your avitar, you're on the 747?
That is correct - the classics...
iaflyer
Fuel burn
B737-200 with JT8D-17(A) engines is 9,000 to 10,000 pph per engine.
Yeah, but....
Spooky 1 said:
One million pounds of fuel in two minutes..............shuttle launch.
There is no reduce T/O thrust, no T/O FLEX!!!!!
The two hairdryers on the back of the 145 each burn about 3000/hr at takeoff (at least thats the ballpark number I look for when I say "thrust set"). Rolls back to about 2500-2600 for the initial climb after you hit the CLB button. It's not "big tin", but it's a comparison.
