It depends:
Premium or Regular?
The RJ's were suppose to be the answer to aviation's problems.
Cheaper? More fuel Efficient? More flights per day.
I'd like to actually know what the fuel burn difference is between the CRJ and the most popular Boeing 737.
Is the CRJ really that much more efficient?
That is a good question but you also have to factor in the distance of the route and the loads. A half full 737 would be much less efficient than a full RJ, etc.
Not really the answer to your original question, but along the same lines:
I fly the 170/175, and have spent a lot of time jumpseating on the A319/320. Comparing the two aircraft, I would say that the 170/175 is half the weight (max gross), carries half the passengers, and burns pretty much exactly half the fuel. So, the Embraer is not necessarily more efficient, but it brings mainline efficiency to smaller aircraft. The big perk for the Embraer is that (labor aside, of course) you can get similar cost per mile while flying full, as opposed to flying with empty seats. The ability to fly with fewer open seats is what makes all regional jets more attractive in today's environment. Or at least last year's market.
If you want specific burn numbers, I say I see fuel flows of 1700-1850 lbs/hr/eng flying at high weights, FL300-380, at .78M. If we pull back to .74M, the fuel flows drop about 100 lbs/hr/eng. That is flying 86 people around. In the mid-20's for cruise altitude, fuel flows go up to 2000-2100 lbs/hr/eng while flying at 300 kts or so.
A lot of our 170/175 flying at Republic is east coast hops of short duration. On those flights we rarely get up to an efficient altitude. I have had ATC stop us regularly at 17000 for an hour long flight when heading into PHL. No one is efficient at those altitudes unless you are beating the air into submission with a pair of props.
I don't know what 737s and A320s burn at idle on the ground, but it is a relevant comparison for east coast flying, as we can easily spend 1.5-2 hours taxiing before a flight of equal duration. The 170/175 burns about 600 lbs/hr/eng at idle on the ground. Single engine taxi is the norm. If you also have the APU running, it is an additional 300 lbs/hr.
For a benchmark, on a PHL-IAH leg the 170/175 will burn about 11000 lbs total with average headwinds.
Hope this helps. I'll try to remember to post some Specific Range numbers, which would make for a more accurate comparison.
The CRJ-200 is burning about 2500 lbs/hr at .74 up above FL300.
Another thing to concider is how much revenue does each seat produce. If you replace a full 150 seat airplane with a full 50 seat airplane and you do the marketing/pricing right you can cherry pick the 50 highest paying passengers off the 150 seat airplane and end up getting a lot more revenue per seat with the 50 seater. Basically with the smaller airplane you can forget about the $99 3 month advance purchase people and focus on the $399 1 week and the $599 1 day advance purchase people. That's why the RJs work even though the seat mile costs are higher.
Scott
Those 50 seaters are really working out well right now. Just ask Boyd.
Scott
Scott
CRJ Cruise at 30,000 feet = 2500 Pounds per hour
737-700 Cruise at 30,000 = 4500 Pounds per hour
It certainly looks as if the 737 is more efficient if both planes are full of people
Throw in Domestic Airspace Issues..... Boeing looks pretty good!
Pappa, I'm still standing by my numbers as good rules of thumb. I spent 6 years flying CRJs at Comair, so I'm pretty sure of the fuel burn we planned. I'd love to stay and debate the fuel burns you stated, but I have to go and fly my 737-700 to PHX.
What kind of fuel burns do these two aircraft have:
1. CRJ (50 seater)
2. 737-700
I'd be curious to see the difference ?
thanks
