sydeseet
Huge Member
- Nov 26, 2001
Some good info here. A lesson I learned from an ARGUS inspector is do NOT write it down unless you are always going to abide by it. Period. Otherwise, as it has been stated, you are throwing your own rope around the limb and then waiting for the opportunity to put the round end around your neck. Common sense says that if you're not going to abide by it then why go to the trouble of publishing it anyway? A FOM is worthless unless it is adhered to, enforced, and practical.
As far as the FAA enforcing the violation of a Pt 91 FOM but not of a FAR, I doubt they would have much ground to stand on in a legal proceeding. The inspector may get uptight about the FOM violation initially but it is not a legally binding document unless it is required and has a FSDO stamp on it. Otherwise 14 CFR 91 would rule.
This is legal wrangling defined in my opinion.
