Hose A. Jiminez
- May 20, 2003
Wasted said:Not all of them are that bad.
Hose A. Jiminez said:geek.
Cardinal said:....The KC135 lost in Alaska was only doing 150kts when it was brought down.
I would think that anything after V1, makes the "airborne" part, semantics.Beertini said:The aircraft that crashed in Alaska years ago was actually an AWACS. It ingested (21 I think) Canadian geese into the #1 and #2 engines while on takeoff roll and subsequently crashed after continuing the takeoff. Sorry, but that accident isn't a good example for airborne bird strike discussions.
Beertini
FN FAL said:I would think that anything after V1, makes the "airborne" part, semantics.
negatory said:(I was trying to find information or recommendation from Flight Safety Foundation about high speed at low altitudes but could not find anything.)
Cardinal said:The KC135 lost in Alaska was only doing 150kts when it was brought down.
negatory said:..high speed at low altitudes
Thedude said:The test they did was flawed and they addmitted it on a later show. They were firing a frozen chicken and a PA-28 window.
If you have ever seen the FAA video of the real testing you would have known this was bull from the get go. Large a/c windows are multi-layered and are heated which makes the a little more flexable than you standard windscreen.
I used to love coming in from off shore into JFK and being able to keep the speed up to at least 300kts.
248to2.8 said:If you hit a bird at 250 or 300, it's still going to do a hell of a lot of damage. That last 50 knots won't do much.
As my screen name suggests, We used to fly the beech at 248 kts to 2.8 dme. Back then I had forgotten about the little 200 within 4 rule. Now I tame it down a bit. But man the controllers loved us.
mdanno808 said:I am not sure where the 250 below 10 rule came from in the US, but it is definitely not a world wide thing. One things for sure, unless you're paid by the hour (which I am not) the faster you fly the more your hourly wage ends up being.
