http://www.falconjet.com/7x/
Does anyone know which airplane (s) will be in direct competition with the 7x?
Kingairrick said:Because it will probably fly 5700NM with 8 Pax out of a 4000' strip.Try that with a Gulfstream, or any twin jet.
mzaharis said:Quick comparison (all from respective mfg'rs websites, except for prices, from ainonline.com)
7X - 37.5 Million
Range - 5700 nm (NBAA reserves, 8 passengers, 3 crew, Mach .80)
Cabin size - 6' 2" h by 39'1" l by 7'8" w (300 sq ft)
G500 - 37.5 Million
Range - 5800 NM (8 pass, 3 crew, NBAA reserves, unknown mach - assumed to be best range - GVFLYER?)
Cabin size 6'2" h by 45'1" l by 7'4" w - 331 sq ft
AA717driver said:...I came up with 38,000 lb burn. So, it's pretty much irelevent to this discussion...
saviboy said:isn't the range 5700nm for the 7x?
and it appears to be 4350nm for the g450 and 6750nm for the g550.
If the price is so high, why would somebody buy a 7x versus a gulfstream? fly by wire? 3rd engine?
sleepy said:Because you get a better cabin with the Falcon. The Gulfstream is a very narrow tube, and thus is not very confortable on long flights.
2000flyer said:AA, how on earth can you say it's irrelevant to this discussion? If the G500, or 550, will burn 38,000 (or 32,000 w/o reserves) pounds on a 5700nm trip, and the 7X only holds 28,900 pounds but can do the same trip with reserves, it sure sounds pretty darn relavant to me!
2000Flyer
2000flyer said:All I've heard is the first one or two are destined for the U.S. DFJ is keeping names under wraps for obvious reasons.
It is also my understanding that training will be provided by SimuFlite's new facility to be built somewhere in the NY/NJ area.
Last I heard, DFJ was still trying to get the FAA and EASA to buy off on a plan that type ratings would be EASy types, with differences for each aircraft, rather than a separate type for each model. That would be great if it happens. They (FAA) bought off on the common Airbus type, as well as the common DA50/900 type, however, I've heard they're balking at the EASy type, so we'll see.
2000Flyer
