ultrarunner
- Nov 26, 2001
How well do the boots work? I can't fathom why they would make a boot on a 2001 airplane, unless you're Cessna. Not enough power from the engines for hot wing I presume?
Because the 150 was built on top of the Astra type certificate. And when you're essentially making a home-built it starts getting MASSIVELY expensive to do a re-design of ANY system, as opposed to just putting together the existing systems.
There is actually no better example of this philosophy than the Lear 20/30/50/60 series.
You don't have this issue with clean-sheet designs, like the follow-on G250 vs. the G200.
Ultra
