Falcon 50/Hawker 800XP Performance Info
jrod
Member
need some performance info for the Falcon 50 and the Hawker 800XP.
Assume 1200 lb payload
Range from 4500' runway @ 1000 feet elevation, ISA +20
Range from 4500' runway @ 1000 feet elevation, ISA +30
Range from 6000' runway @ SL elevation ISA+20
Range from 6000' runway @ SL elevation ISA+30
Thanks in advance.
For Hawker 800XP without winglets.
-About 2 hours with a BOW of 16300
A little over an hour.
Can take off at max minus 300..around 5.5 hours depending on how you fly it
Around 2.5 hours
These are rough numbers that can vary by how you fly it, and what you want to land with. Used around 440ktas and landing with around 1800#. Maybe 433 to stretch it out for the longer legs. Between .75 and .76
Hope this helps.
