FAA ramp check, reverse extrapolation???
apcooper
Dude, where's my country?
If an inspector does a ramp check on you and gets to looking at the W&B data and notices the plane is 20lbs under gross. Lets say then he asks where you came from and you tell him you came from an arpt 300nm away. My question is can the inspector violate you for flying over gross eventhought this would be based on reverse extrapolation since obviously you must have taken off over gross eventhough you are legal when you land???
...Yes he can, and yes he will. If you try to tell him he can't do something you could be in for a rude awakeing...muy pronto.
You were illegal at some point, duh, and sitting there is evidence that you broke the law?
How could he possibly not be able to bust you?
As a follow up
Do any of you use the "standard FAA male/female/bag" weights whenflying something light like a 172 or do you use actual weights? And if you used the "standard" weights, would he still violate you?
-mini
It is rather important to try and use the actual bag and pax weights in the small light aircraft. I would never base this on the average and yes the FAA can and will violate you depending on the inspector. Some are nicer than others. Got the ramp check one day and he asked if the ops specs were current in the aircraft as well as asking if I had latest chart revisions. I then asked him how would he actually know if I indeed had the latest revisions or expired ones? . I think we both laughed at about the same time. The majority of inspectors are not out there to make life difficult, instead they want to ensure that safety is not being compromised. I think most of the p!ssing and moaning coming from those are in the majority who may have had possibly one bad experience or probably have never even gotten ramp checked and have bought into urban legends. Be safe, know your operation, know your airplane, know the far's, then you have nothing to worry about. Be unsafe, take chances, try and cut the corners, allow management to force you to do things that are unsafe, etc, then you deserve to get violated.
You have happened to stumble upon one of my pet peeves. (Caution: Lead Sled is climbing up on his soap box. :rolleyes: )
You need to remember that the FAA's "Prime Directive" is that the ultimate responsibility for the flight resides with the PIC. Personally, I check the weight and balance numbers on the aircraft I fly. If there's ever an accident or serious incident, the weight and balance will be scrutinized as part of the investigation. For your own peace of mind - after all, it will be your license - you owe it to yourself to make sure that you are using correct numbers.
Typically 121 operations are allowed to use "standard" passenger weights. These weights will be reasonably accurate when averaged out over a passenger count that could be as high as a few hundred people. Also, to be say a couple of thousand pounds off, one way or another on a 300,000 pound airplane isn't as significant as being 300 pounds off on a 1600 pound Cessna. The FAA standard passenger weights were recently revised upward. Most part 135 operators aren't allowed to use standard weights.Aircraft the are operated under Part 135 must be reweighed every couple of years. Weighing an aircraft isn't a big deal and calculating the aircraft's center of gravity doesn't require a doctorate in mathematics.
Whats the big deal over weight and center of gravity issues? I'll explain it in relation to the business jets that I fly, but it also relates directly with larger airline equipment and smaller general aviation aircraft...
There are several weight and balance issues that pilots must address prior to each and every flight in jet aircraft. There are several “maximum weights” that have to be dealt with. For example, the Maximum Ramp Weight is the maximum weight that the aircraft is allowed to weigh sitting on the ramp loaded with fuel, passengers, baggage, crew, etc. There is the Maximum Takeoff Weight which reflects the maximum weight that the airplane can weigh at takeoff; the Maximum Landing Weight which is as the name implies, the maximum weight at which the airplane can be landed. (There are some other “maximum” weights, but these aren’t germane to this discussion.)
There are many reasons why aircraft engineers and designers establish these various weight limitations – some are structural in nature, others are performance related. The same concept applies to the aircraft’s center of gravity (CG) or balance point. There are prescribed limits to the range of locations along which the aircraft’s center of gravity or balance point may fall. Again, these limits exist for structural, performance and/or handling reasons.
As far as the various weight and CG limits go, they are out of the aircraft operator’s control. They are established by factory aeronautical engineers and aircraft designers, verified by factory and FAA test pilots, and approved and certified by both the factory and the FAA.
While these weights are listed as “maximum” weights, it does not mean that pilots are free to operate their aircraft at these specific maximum weights. Typically, pilots are required to operate the aircraft at a lower weight for any one of several reasons. FAA regulations require that transport category aircraft, be they airliners or bizjets, be operated at a weight and with a center of gravity location that will allow it to achieve a certain minimum level of performance in the event of an engine failure during takeoff. (You guys flying light twins have no such performance requirement and your aircraft typically have very poor to nonexistant single engine performance.) The required performance level varies upon the terrain and obstacles surrounding the airport. However, the basic requirement is this: In the event of an engine failure during takeoff, the aircraft must be able to either (1) stop on the remaining runway; or (2) continue the takeoff and clear all terrain and charted obstacles on the assigned flight path by a designated vertical distance. In other words, if an engine fails on takeoff, the aircraft must either be able to stop on the remaining runway or be light enough to continue the takeoff on the remaining engine and be able to climb to a safe altitude and return to an airport for landing – a guaranteed safe takeoff if you will.
The manufacturer of each transport category aircraft is required to furnish, and the crew is required to use, factory certified, FAA approved performance charts and/or other data that allows them to determine the maximum weight that each airplane can weigh for each combination of airport altitude, outside air temperature, runway length, runway slope, etc. These charts, as can be imagined, can be pretty complex; never the less, pilots are under a federally mandated legal obligation to calculate the aircraft takeoff performance and to operate the aircraft accordingly.
OK, now back to light single engine aircraft operations...
We've all seen guy who will load up their friends and family in their trusty Cessna 172 and blast off into the wild blue yonder without even bothering to check the weight and balance. They usually always performed a reasonably good walk around inspection of the aircraft - but that's as far as it went. Look up the duties of the PIC in the FARs and you'll see why just performing a walk around isn't enough. How many times have you seen a couple of lard a$$es get out of a Cessna 152?
Those who operate under parts 121 and/or 135 have different obligations, and in may cases a lot of help when it come to complying with their weight and balance requirements. I can only assume that most airline captains have never had to calculate the weight and balance of one of his typical passenger flights in their Boeing or Airbus. That doesn't mean that there isn't some one at his company who hasn't looked at each and every flight prior to issuing the dispatch release. 135 pilots have to fill out a two-part weight and balance document prior to each and every takeoff. One copy is carried on board the airplane and goes into a file at the completion of the flight. The other copy is either left with the FBO, etc. or faxed back to base. Us non-commercial guys flying light aircraft and bizjets under Part 91 have to fend for ourselves. Many times, the pilots of these aircraft just simply don't bother to do it. After all, "It's never killed me before." In general aviation, complaciency is one of the biggest killers.
'Sled
hahaha...thats like saying...."If I stole a candy bar in aconveniencestore and then threw it in the trash when I got outside, canthey stillcharge me with theft?" :p
why does my text keep running together like that? Weird.
rumpletumbler said:
hahaha...thats like saying...."If I stole a candybar in aconveniencestore and then threw it in the trash when I gotoutside, canthey stillcharge me with theft?" :p
kind of related to your example...
I was in retail for many years. If someone stole from us and wewere running after them and they dropped the item or threw it away,that was it. There's nothing we could have done if we didn'tcatch them with it on them. A real PITA.
...but anywho...
when I flew 135 as soon as I landed all paperwork went into the trash. right before I hit the exit door at the FBO.
If you were flying 135, the weight and balance paperwork had better not have hit the trash...if you were required to keep records and do weight and balance, your company has record keeping obligations for 30 days on the load manifest.
If you're talking Part 91 operations, you should use actual weights. Certain Part 135, and most 121, use standard weights. However, Leadsled already detailed in fine the particulars for using actual weights, and being accurate with actual weights.
We took a load out of Monterey, Mexico once. It was our first load after arriving, and we took the load on by quantity. Very easy to figure and know performance because we always take exactly the same amount of liquid. Unbeknownst to us, the local yokels on the ground didn't mix at 9 lbs to the gallon, but at somewhere between twelve and forteen pounds to the gallon. We found that out right after rotation when the telephone poles were slipping by even closer than usual. Even in a larger airplane, it adds up fast. In a small airplane...how far can you fly in ground effect? How does your airpane fly with the CG outside the envelope?
Don't be the first kid on your block to find out.
Only for Multiengine. Single engine has no record keeping obligations, trash it asap, no need to hang yourself.
What was being mixed?
I have been ramped checked twice, both time at KLOU, once in a big ole Cessna 150 and we where like 35 lbs over but the inspector never said anything about it, I guess he knew too that there is hardly anyway to fly a 150 with 2 people under gross. The other time was in a Diamond Star, I again was like 30 lbs over gross, but I had not done a weight and balance, I knew I was within CG from previous trips so there was no point, he asked if I had a done a weight and balance, I said no, he said are you sure you are within CG I said yes, he said well I could make you figure a CG right now but I will take your word for it. Guess I lucked out, he never did add up out weight so he never knew I was over gross. I did know how heavy we where just not to the MM where out CG was. (Diamond Aircraft POH and Weight and Balance are all in Metric, I HATE THAT SO MUCH!!! Wouldnt be so bad except I'm so used to inches and pounds, not meters and kilograms). One other thing, I'm not going to tell anyone to not figure a CG like I do. I just feel that after you have done 100's of them and nothing hardly ever changes, you can look at the chart and see that you would have to put another airplane in the back seat before the CG would be out, thats its not something you have to do. If or when you do get ramp checked its kinda handy not to have done a weight and balance b/c if you where over gross you can slant the one you have to do in front of them in your favor. Little corrections will get the job done, unless your way out, and then you do need to be taought a less by the FAA. But dont go not figuring your CG's just cause someone else does not. Most of the time aircraft will fly ok outside of CG, just like many will fly just fine up to 10% over gross, but that still does not mean its safe or a good practice. Most of the time you would absolutly have to be an idiot to get an aircraft so far out of center that you could not control it. Over loading on the other hand is very easy and tempting, you have to watch out about it. I only over gross an aircraft with the understanding that for every extra pound that I add I'm shorting my glide distance in single or reducing my abality to climb with just one fan turning on a twin. If I run an aircraft at gross for a few flights and get a good feel for it then I usually have no problem going 30 or 40lbs over for a single, but for a twin you really have to watch your weight limit, its there for a reason. They perform crappy enough under gross on one engine, if you have a twin over gross and you loose and engine you need to be looking for a close spot to land. Fly safley
REALLY?
ramp check
Just ask him for some sort of official ID before you start asking questions! THrow him the whole "TSA-Homeland security" line. I did it once and the guy had to go back to his car to get it :-) At that point, I made my way to run-up and was on my way. No bull story there, but I sweated all the way back home hoping that he didn't catch the tail #. A better though, just keep it undergross!
FlyJordan said:
...Most of the time aircraft will fly ok outside of CG, just like many will fly just fine up to 10% over gross...I only over gross an aircraft with the understanding that for every extra pound that I add I'm shorting my glide distance in single or reducing my abality to climb with just one fan turning on a twin...If I run an aircraft at gross for a few flights and get a good feel for it then I usually have no problem going 30 or 40lbs over for a single, but for a twin you really have to watch your weight limit, its there for a reason. They perform crappy enough under gross on one engine, if you have a twin over gross and you loose and engine you need to be looking for a close spot to land. Fly safley
Thank you FlyJordan for sharing the wisdom and gained from your vast (less than 200 hours) experience. If I sound sarcastic, I am. I'll be the first to admit that running 30 or 40 lbs over on a light single won't cause it to fall out of the sky... However, when you start down that path you're really starting to walk in a mine field if you know what I mean. Not all aircraft have loading and flight characteristics as benign as the trainers you've been flying.
"Sled
JonJohn82 said:
What do the "ramp checkers" look at and ask for when one gets "ramp checked"?
Whatever they want.
Certificates and documents, weight and balance perhaps, maybe takeoff and landing field lengths (I doubt it), the bigger the equipment, the more there is to see...MELs, Manuals, D-Cell Battery flash lights, fire extinguishers...
If they want to be a pr*ck about it, I'm sure they could ask to see anything they want...but they have more important things to do with their time than to harass everyone on the ramp for 20 minutes per plane...so I'm told
-mini
What regulation under 91 requires you to have the Weight and Balance anyway? Yes sir, I did it, once I saw I was in limits, I chucked it in the trash. The regulation doesn't require you to have it on your person. I doubt any attempted violation of an individual for simply not having a W&B wouldn't make it past the region corp counsel office.
Later
Later
I agree, but if they were anal enough, they could make you do one right there.
Just some of the things they could want to see is all...
Oh and that compass...make sure it's full of fluid...Acid Free White Keroseen...no air bubbles...gotta be full
-mini
I think I missed something here. Why would you want to fly an aircraft with a compass (only half full of fluid) that didn't work to mfg. specs?? If some one pointed out a problem in your aircraft shouldn't you be happy? With your entire 100 hours of flight experience are you saying you know more about that compass than the designer or general airworthiness standards?
The attitude displayed by some (during a ramp check) does not serve them well and may bite them hard. I wonder if they also play with matches while sitting on top of a keg of gunpowder.
Be professional, knowledgeable, and calm even though the others around you are not. Some call it maturity.
Getting advice on how to act during a ramp check from a BBS is sometimes like getting advice on how not to get a girl pregnant from a high school locker room. It doesn't always work.....
You guys crack me up.
JAFI
JAFI said:
I think I missed something here. Why would you want to fly an aircraft with a compass (only half full of fluid) that didn't work to mfg. specs?? If some one pointed out a problem in your aircraft shouldn't you be happy? With your entire 100 hours of flight experience are you saying you know more about that compass than the designer or general airworthiness standards?...
Where did I say I would be upset if someone pointed out that my aircraft was broke or otherwise unairworthy? Would I want to fly an aircraft that isn't airworthy? Nope. Would I want to get "busted" for something stupid like an air bubble at the top of the compass? Nope.
I was merely offering up some advice on information which I have picked up during my "entire 100 hours of flight experience".
The compass doesn't have to be "only half full of fluid" to be unairworthy. I'm surprised you don't know this with your over 100 hours of flight experience.
If there is even a bubble at the top, it can be determined that the compass is not full of fluid, therefore making your aircraft legally unairworthy.
Honestly, I was just trying to help out a fellow-aviator with something that (from what I've read/heard from more experienced pilots than you and I combined) can easily be overlooked, and an inspector who is having a bad day (or whatever) could bust you on it.
...but then you already knew that.
-mini
PS
If it seems like there's some attitude in this post, there is. Next time make sure you inform me earlier which posts have a prerequisite of 8000 hours to attempt to help...then I can just sit here and study some more.
But does that compass have a dated correction card?
As for throwing things into the trash, depending on the state, that stuff becomes public domain once it hits the rim. All a determined Fed has to do is pull it out and have fun.
Put yourself in a 3-letter agencies' investigator position. You have someone you are trying to bust for whatever reason. In the trash you know are the documents that will finally let you make that bust. You will be able to use that evidence in court without any threat of it being thrown out, it's public domain.
Even if that paperwork is shredded with week old egg salad on it, do you think any agency is going to let that stop them?
The trash is not a safe haven. Shredded paperwork in the trash is an invitation for someone to look there first.
Fly SAFE!
Jedi Nein
Good grief, please tell me you're not serious. They are just numbers, the arithmetic is no harder or different in metric than it is in our system.
Actually in a single you will get the same glide distance regandless of the weight. You will just use a higher speed for best glide. If flying a piston twin say 10% over gross and I lost an engine after takeoff at 500ft I'd simply pull back the good engine a few inches of MP, pitch for VYSE +3 kts and set it down in a field just like a single. You could glide a lot further in this scenario than in a single since I'd use the good engine to MINIMIZE DRIFTDOWN, NOT to maintain altitude and end up in a VMC rollover and be killed forsure!! If Taking off from Aspen even well under gross I'd do this same thing because no non-turbo piston twin has a chance of climbing at 10,000ft density alt on one engine!
Its just a pain
FlyJordan said:
Its just a pain
Hmmm, so you really are serious. OK I'm fascinated by this.
Explain this to me because I'm really not seeing it. Let's say that you's adding moments in this airplane your weight is 70 kilos andh the pilot seat has an arm of 96 cm. Please explain in detail how it is substantially more challenging or difficult to multiply 96 X 70, than it is to multiply 155 X 38 (the same weight and arm in our system)
Its not that, your gross weight is in kg, fuel is in kg, payload in is kg. So many kg's of fuel do you have, how many kg's do all your passengers weigh, how many kg's of baggage do you have? Once its in metric I dont care if they figure it in slugs, its just converting all the weights that is a pain, Its not like I think its impossible, its not even hard, its just a pain to do.
