My question pertains to question 4360 of the FAA Instrument-Airplane Written Test. The question asks for time en route and provides limited information. One of the components missing from the flight plan (and necessary for calculations) is wind direction and speed. The flight plan specifies a crusing altitude of 11,000 ft. Winds aloft at different altitudes are also provided in the problem: 2422+11 at 9,000 ft and 2324+5 at 12,000 ft. There is also an 18 degree east variation, which is given. To me it would made sense to interpolate these values for the wind at 11,000 ft, which I figured at 215 degrees at 23 kt. However, when checking the answer to the problem in the Gleim's Study Guide, it instructs you to use the values for the wind at 12,000 ft, which is notes is "closest to the planned altitude of 11,000 ft). MY QUESTION IS: Why wouldn't you interpolate for the values at 11,000 ft in the name of being accurate as possible!? In previous FAA questions on both the Private and Instrument tests, I believe that you are always advised to be as accurate as possible when doing computations. Why then cut a corner is this problem? If anyone can shed some light on this, I would greatly appreciate it.
