ToiletDuck
Ninja
- Apr 23, 2005
you'll be lucky to see 20k yr. The problem is being a 135 operator, if they have a check airman doing the ride then they can get anyone to sit in the right seat. So that means low pay.
if you have to go to the FAA for the check then you may see 30k tops cause you'll actually have to perform.
Outside of a cargo outfit, I've not seen pay as low as 20K.
You should expect about 35k. However, if you are typed in the ERJ, you should expect to enter the company as a co-captain at a bare minimum of $45K and work your way into a captain slot of $60K (bare min. again). With out the type, $35k is a reasonable number.
With your time and if you are typed in the ERJ you can find contract jobs in the Legacy which in the left seat can pay $400-700 per day.
