expected JetBlue New Hire normal work days
skysurfer76
Active member
I have an interview with JB coming up in a couple of weeks....
I wanting to know what kind of schedule I would most likely see, Im not located at a base, so i would have to commute out from CLT or RDU. Im thinking it would normaly run like a 4 on and 3 off and 3 on 4 off ect....
my question is, working the 4 on and 3 off.....it seems to me that i would have to be commuting on two of my days off? or does the company usually give you a late start on day one and an early shutdown on the last duty day?
Any thoughts or expriences from other on how JetBlue usuallly runs the reserve lines?
With the new FSM rules your schedule is locked down. What you are assigned is what you will sit RSV.
I just started a 5 day on RSV period. I'm on a 7am window first day (try to commute with that). They will tell you what it's supposed to be, but scheduling can do what ever they want.
The new FSM (Flight Scheduling Manual) is a touchy subject. So it will be interesting to see the replies. I'll try and give an unbiased answer.
JetBlue has a preference bid system. After you are awarded your reserve schedule from PBS, there are a few "48 hour windows" that allow you to modify the award through a system called FLiCA (Flightline Internet Crew Access). For example, the first window is a drop window. You would put in your preference (via FLiCA) as to what day(s) you might want to drop. Each window is open for 48 hours and is seniority based. Other windows include swap, pick up, and move up. Once all of these windows close, the first come first serve window opens and remains open until the end of the awarded bid month.
Once the first come first serve window is open, it's a free for all. There are limits on what you can swap, add, or drop during this window. You are limited based on reserve coverage numbers for that month. For example, if the minimum reserve in JFK for Monday is 20, and the actual number is either 20 or below, you would not be able to drop that day. If it is 21, then you can swap or drop that day. There are other limitations as well, but this would become a novel if I explained them.
The issue now is that the reserve numbers are usually at or below minimum coverage for the month, thereby not allowing many to manipulate their schedules. The numbers change depending on the month and time of year. For example, in October, the numbers may have a better chance of being above minimum coverage because there is less flying that time of year. For July, the numbers tend to be either at or below minimum coverage, because there is more flying. Of course, this also depends on your seat. Oh, and you will have a minimum of 12 days off for 30 day bid months and 13 off for 31 day bid months.
Of course there are more details, but that's pretty much it in a nutshell. Opinions will vary regarding why the reserve numbers are what they are.
Hope this helps. Good luck!
If you want a j.o.b at jetBlue don't even go there during an interview.
You will be complaining by just asking.
If they ask "how do you feel about commuting in the day before" you must answer "I love it because that means I'm now a jetBlue pilot".
Every negative has a bright side and you must uncover it for the interviewer.
Yeahhhhhh!!!!
Skysurfer, as a general rule, you need to add, at a minimum, 1.5 days to your schedule to allow for the commute. There will be MANY times where you have to commute in the day previous to your rotation because of the show time, and MANY times where you will commute home the day following your rotation because of your finish time.
It's just going to be hit and miss each and every bid period. And QOL will really suck for a while.
The sheer thought of commuting to JFK gives me the creeps.
There may be
I would not call it a "lock down". However, you must be quick when the FCFS is first opened. Example....I had 5 commutes for RSV in June when my line was awarded. Now I have 3 commutes with 18 days off.....3 PTO and 1 pre-released day.
So yes I used PTO but now I'm off from the 14th-28th of June. This method must be used for vacation if you can't hold squat!
Quick? If the numbers are red young grasshopper, you are locked down. Call it what you want. How about we call it a "cool" process?:laugh:
Do you really think using a month and a half worths of vacation and sick time (PTO) is worth having a few extra days off? Is this a good thing to you? Serious question...:confused:
Easy, I'm on ur side. I don't recall ever saying it was good, just neccesary.
Yes, using PTO is worth it to me. We'll be getting horizontal on our 19% owners across the pond. Have a fun summer!
If you live in base on reserve its a totally different company.....even with the FSM work rules I've flown a total of 1 hour, yes 1 hour on the bus for may....got an extra day off for may (prl) and started late on most of my first days of reserve......now heading into the busy months, I'm on reserve at least 2 days on the weekend, (usually hold all weekends off). Its all different depending on base and aircraft.
Obviously you see some friction here about our new work rules manual. There will be days you can commute same day...and some times you'll waste some off days. I'm a line holder and I normally get trips with one day commutable...sometimes both ends are. I live in ATL...no JB here. RDU and CLT has a LOT of JB guys. Lots of former USAirways fellas. CLT is the hardest to get out of. I'd stick with RDU...a few guys I know head to CAE...they live between there and RDU.
Bottom line...most of us don't fully agree with most of the stuff in our new manual. I'm guessing after a few months with the manual "live", we will get some changes. I like working here. Is it perfect? No. Better than other places...mostly. If you make it...I think you'll like it here.
Good luck on your interview. Don't let these other guys get you down.
I agree but I would be between CAE and CLT rather than RDU. JB might be tight out of CLT but many options to LGA, PHL, DCA-LGA (shuttle) etc.. on Airways.
Skysurfer,
To ask what your schedule will be like on RSV and commuting is foolish. It's gonna suck no matter how you look at it. So don't ask. Drink the juice if you want the job.
Good luck to ya!
JetBlue is great. SUPER GREAT. DUPER even.
If you live in base on reserve its a totally different company.....now heading into the busy months, I'm on reserve at least 2 days on the weekend, (usually hold all weekends off). Its all different depending on base and aircraft.
Don't forget seniority!!
What's a weekend? I have work and no work days. That said, I have no kids and a boat. The lakes and rivers are nice durring the week, plus the strippers are off!:pimp:
thanks guys, just trying to get a feel for things...thanks for the imput...
The 'm' and 'n' keys are right next to eachother on the keyboard, right? Guess it was just a typo and that you really didn't think that imput is a word.:)
GP
There may be
I wouldn't bet on a JFK commute. I'd be planning for a BOS commute if I was a new hire. That's where the growth seems to be. Maybe MCO as well.
Most new hires will be based in BOS and possibly MCO, doubtful many will go to JFK as they are reducing crew numbers there.
CLT - BOS isn't as tough as CLT JFK commuting, JB is going to 4 flights a day and US Air has several as well.
Life on reserve sucks. Be prepared to be on reserve for a long time.
I agree with BOS and MCO. Some guys are going to leave JFK for MCO I'm sure. But I digress.
RSV in BOS isn't horrible. Commuting to RSV does suck no doubt, but there are lots of things to do in BOS if you keep yourself busy. I skipped JFK so I couldn't tell you how that is. By the time you get here the agressive pick up "should" be working so you'll have more opportunity to work.
Just guessing, but time on RSV will probably be 18-36 mo. with the A/C deliveries over the next 2-3yrs.
Aggressive pick up is a mirage. Ask the WRC guys and they will tell you that it was designed to formalize what is currently the policy and that is to pay reserves to fly on a day off only as the last possible resort. The incidence of reserves flying on days off and being paid above guarantee today will be the same or nearly the same when the so called aggressive pick up is activated.
Of the aircraft scheduled for delivery I would count exact none arriving.
