ERAU Extended Campus Degrees
STLCFII
Active member
Hey everyone,
Just wondering how the ANG/AF view the BS degrees from ERAUs Extended Campuses? Is there any problem with getting a degree from them and going into the ANG? Do they look down on these ways of earning a BS? Thanks a lot
Brian
A peice of paper is a piece of paper
I have a BS and MAS from the ERAU Extended campus.
An ERAU Degree from the Extended Campus has the same wieght if not more than going to the real school.
Next to going to the AF Academy, Any aviation oriented school is very good. Now if you are in South Carolina and didn't go to the Citidel then you might have a problem.
But I can bet that if a unit was to look at two dudes, one who worked a job and when to night school at the extended campus and someone who went to school full-time at a normal institution or even at the Daytona ERAU campus. The Extended Campus grad would win out. Becuase it shows that not only that you have a work ethic, but you are all determined enough to put in the extra time getting a degree after you put in a days labor.
I also bet 50% of Military pilots that have Masters Degrees got them from ERAU extended campus.
