uwochris
Flightinfo's sexiest user
- Dec 21, 2001
Just looking for some different opinions on the following scenario:
You've been cleared to enter a hold, inbound on your final approach course for an NDB app. The turns are to be made on the opposite side of the procedure turn. Now assume it's a direct entry, and you experience an engine failure, a little before crossing the NDB to enter the hold.
Would you:
A) Keep flying the airplane, maintain control. Enter the hold as normal, then make a mayday call for an approach.
B) Keep flying the airplane, maintain control. Instead of entering the hold, you enter the procedure turn (opposite side to which holding pattern is supposed to be). Make a mayday call for an approach.
C) Keep flying the airplane, and expedite the approach immediately (i.e. you neither enter the hold nor the procedure turn, but go straight for the approach).
I know there are a lot of variables that should be considered. But for the sake, let's assume that the plane is controllable on 1 engine with good enough performance to maintain flight.
I would personally choose option A), since you've been cleared to enter the hold, and you know for a fact that that side is protected (ie. you're not always sure as to why ATC might make you hold on the opposite side of the PT). The only problem I see is that if you are at a high altitude, you won't be sure if it's safe to descend to your PT altitude, since that altitude only applies to the PT side, and not the opposite side (where the hold is to take place).
Opinions?
Would you:
Opinions?
