i hate to break it to you guys ... but statistically, helicopters are way more dangerous and you are more likely to die in an engine failure than in a fixed wing aircraft. Yes, theoretically, if you are Mr Skilled pilot you could bring the helicopter to a perfect landing in an autorotation. But the statistics say more pilots screw up in a helicopter than in an airplane, when it comes to engine failures.
And trust me, a helicopter can be overwhelming!
In an Autorotation, you usually try to maintain best glide speed (~40kts) and come down to about 50 feet that way.... Then you flare the aircraft to reduce speed. Once around 20ft, you slowly start to pull collective (increase AoA on blades) - this will decrease rotor RPM and cushion the landing. If done properly, you walk away without a scratch on the helo.
But comon mistakes are early flaring, early collective application, tail rotor strike (flaring to late & to much), hitting the ground to hard and bouncing back up + subsequently flipping over), etc....
