EMB 120 Prop
The_Russian
Low Level Pilot
Just curious,
How many of you operate the props at 80% during cruise flight? If you don't, why don't you?
Just curious,
Not so much in straight and level cruise but I do it all the time fo the longer descents. According to SkyWest EMB SOP APPENDIX B Page: B-42
PERFORMANCE Revision: 08 STANDARD PRACTICE 3500 Date: 01 JAN 06
36. EMB 120 Cruise Torque Chart & Settings – Procedures
...D. SkyWest Airlines cruise is conducted at NP of 85%.
So that's probably why.
80% doesn't give the same cruise TAS as 85% NP.. 80% is good for cruise descents... gives less drag during descent but jack schit for pull during level cruise.
I see the reason to maintain 85%. Better TAS and icing protection. The reason I use 80% (on occasion) is because it is quieter, saves fuel, and reduces the strain on components. And, it definitely reduces the drag in the descent. Truthfully, I am not in any rush. I like to block high, baby!
The reason I posted was an inquiry into any reason that this may cause a mechanical problem or exceed any limitations. Even though I know it doesn't exceed any limitations, my FO's keep saying that I am and I can't seem to get them to justify their statement. From reading the chart in the AFM I am well below the 1305 SHP line and have a max TQ seting or 84% at that NP.
Also, does anyone use a Schedule A climb?
90% NP out of 12,000.
I would like to hear more about his 80% thing. Keep 'em coming.
You want me to take the soviet planes off there? I thought it was a bit fitting with the name and all. Although, I cant wait to take a shot at flying the MiG 21. Personally, I have a great love and respect for eastern built aircraft. Pure steel and black smoke!
Well how does your company tell you to do it? From your comments it sounds like they don't tell you to set the Np at 80% for cruise, or your FOs wouldn't be questioning you about it. Of course you aren't exceeding any limitations, but it probably isn't the most efficient way to run that airplane in cruise. You get paid to fly someone else's airplane, so don't make your own program. Do it the way they want it done.
Apparently 80% Np, 25-35% TQ, 1800 FPM, and 220 KIAS is the least drag configuration for descent. I find it works well for descents into airports that don't require intermediate level-offs (smaller airports).
I am a fan of the 90% Np climb above 12,000'. Especially if you need to climb up into the flight levels. It is much more comfortable for the pax and FA as the noise level and vibrations are reduced. As long as you don't let the airplane get too slow (less than about 165 KIAS), it works well and will get you up into the mid twenties. I have found that trading climb rate for airspeed once you get above FL180 will let you climb at 170 KIAS and 500 FPM up to FL250 most days.
90% climbs are much louder in the flight deck, and since I am up there 120 hours a month the less noise the better. You will have longer block times with 90% though.
I brought along an SPM once on a flight and we attempted to determine the straight scoop on the 90%vs100% climb. I haven't tried it in the cabin but we found that with either setting that you could move the meter around and find 15db change just moving the meter less than a foot in any area. Bottom line, WTFK! If nothing else the 90% climb is of lower frequency and doesn't sound like we are fighting our way to the top from the take off. The climb charts suck though, and you'll really be building block if you use them into the mid twenties. I watch the temps and keep the torque under 84% during the climb. The limit is 800 degrees if we need it, 720 when we can. 600fpm at FL200 isn't going to cut it.
I'm just scared of the props, period, so I run at book RPMs - 85%. The thing with props is that what "feels" quiet and smooth may in fact be resonating at the natural frequency of some important part, which may fail from fatigue at an innoportune time. It's the same reason we don't go CL's Max until cleared for takeoff. Given the history of these death scimitars (where is 14RF SUX?) I do as Embraer asks and try not to think about them. If the noise bothers you, get a better headset, seriously.
I don't know if it's fitting, seeing as you probably wouldn't know half of them if they fell on you. For instance, what does LaGG stand for?
Our profiles state 85%. Good points and good post.
Someone just told me there is an Operations Bulletin from Embraer concerning this subject. Apparently operation at 80% does damage to the quill and can increase the risk of overspeed. This is not confirmed officially and I have never been presented this information. Have any of you? If so, why has the limitation not been officially changed for the safety of crews and passengers? If I get a copy of this, will it effect the operation of this setting in the descent?
There you go. This is a perfect example of why you should always operate an airplane as instructed, and not cowboy around with new procedures. There may be a hidden gotcha.
FWIW, Continental Express pulled their -120s back to 80% Np and they had more overspeeds than even ASA (even though ASA had the most fatalities). So maybe there is something to the ops bulletin.
For what its worth, we were at Np 90 in the climb through FL180 when it happened. I think there is more bending load on the prop at slower Np speed/ higher pitch angle while oprating at 90 vs. the flatter pitch at 100. Not many crews climbed at 90 way back then, so could that have been our final straw on what would eventually have snapped anyhow?
Not nearly as concerned about fan blades now.
14RF SUX
14RF SUX
At least it didn't overspeed on 'ya Warmie ;)
I wrote Embraer and got this back. I am still waiting for the instructor to provide me with the "Ops bulletin". The bulletin most likely does not exist at all, and the guy most likely made it up. It's GIA, go figure.
With regards to your question below,
Q) Recently, I have been advised about an Embraer Operations Bulletin
concerning prop operation in flight being limited to 85%. I was
wondering
if you could email me this operations bulletin for my review.
please consider the following:
A) 85% of Np is considered as a standard point of operation for the
airplane in cruise (just like 100% of Np is for takeoff or 90% for
climb).
These numbers are more related to airplane performance rather than any
limitation imposed by the propeller system.
I've searched then for the propeller operation in flight being limited
to
85% of Np information in our flight ops manuals but didn't find it
anywhere. Do you have the operational bulletin number so I could refer
to
it?
Best regards,
Humberto Hiroyuki Okubo
Flight Operations Engineer
Embraer - S�o Jos� dos Campos
Phone: +55 12 3927 5526
Whats up with people doing the pre/post flight on the BRO and turning the props the wrong way? do these people even know which way they spin?....Anal I know.
I just spin 'em from wherever I am...usually the most convinient spot makes me turn them backwards........oh well.......
WTF! Don't you know it preloads the starter spring :) The back of the prop takes the beating and more so towards the tip. Bringing the blade down from the left side and thats the first thing that comes into focus, then you can scan up the blade. Also, it's easier to make sure you don't smack yourself bringing the blade down.
What really sucks is when the prop turns the wrong way in a strong wind and the starter spring unwinds!!! It takes forever to rewind it back up again!!
starter spring? they didn't teach me that one in ground school, I guess its a big rubber band that you windup ;), and FYI I really don't care which way anyone turns them it was kind of a joke... except the part about me being anal.
I have just read through all of the Embraer Ops bulletins provided by the instructor. None of the ops bulletins say anything about recommended prop operations to prevent overspeed. As long as you stay between the limits of the cruise chart, you are within the limitations of the prop. The only thing that it did specify is that you should not set the power levers below the flight idle stop or secondary flight idle stop. Nor should you rest or press the power levers against the secondary flight idle stop. I guess we all know that already.
