once again, your cat. is based on MAX CERTIFED landing weight, not actual. You are one cat. unless you have to circle at a higher speed, then you use the higher speed Cat.
That would be the case if one were discussing approach speed categories for a terminal procedure. However, this applies to airport codes and pre-designated catagories for each aircraft, as previously shown.
And those codes are still determined by Max Cert landing weight, correct? The circle part was extra for approaches, I agree nothing to do with landing restriction or ARC in this case.
Yes and no. It depends on what you mean. The category is determined by Vref (1.3*Vso) at max landing weight.
