Ear Clogging
maverick_fp00
Total Time
.4K
Maybe somebody has some suggestions for me....
My left ear is always clogged. I can make myself yawn inside the airplane to unclog my ears but my left one never uncloggs. Whenever I am on the ground and for example, I blow my nose, it'll unclog but once I stop blowing it'll clog back up. Sounds kinda funny but it's really annoying.
Anything....??
Thanks Again,
bobbysamd
Total Time
4565
Ear clog
Try the Valsava maneuver. Close your mouth, pinch your nostrils and blow forward (not too hard :eek: ).
Hope that helps. It worked for me when I would be well. If it wasn't working, chances are I had some bug or something.
maverick_fp00
Total Time
.4K
Bobbysamd:
Hey man, that is exactly what I do, but the same thing happens, it'll just clog back up.
Oh well..
Thanks,
propilot
Go Sioux!
Total Time
7800
Try using one of the water removal products available for swimmers ear. I had the same problem. Turned out to be water lodged in my inner ear, apparently from showering. Cleared it up within a couple of uses.
aero99
just a member, not senior
Total Time
10PM
Try hydrogen peroxide(sp?).
If you have any kinda simple infection this will clean it out real good. It will tickle as it bubbles, but seems to work for me everytime I have an ear issue.
Saabslime
Dysfunctional family
Total Time
enough
Or.............just go to a doctor and get some professional advice. It's probably something simple and easy cure. But I know of someone who had an ear infection, didn't go to the doctor and it ended up being a virus that eventually spread to his brain. He's now 28 years old and learning to read "See Spot Run" books again.
bobbysamd
Total Time
4565
Ear block
I agree with the above, then. Maybe you should see your doctor. Pressures inside your ear can blow out your eardrum. I met this student at Riddle who blew out an eardrum. It took eighteen months for it to heal. He did get back his medical. I have no idea if a history of blown-out eardrums kills one's chances with airlines; I heard once it does.
ILLINI
Total Time
Have any of you heard of pilots getting a hole drilled in their ear somewhere or in their sinuses? I heard from a "friend of a friend", that some people have genetic problems that prevents them from equalizing the pressure in their ear or sinuses, which is obviously not good for business if you are a pilot. The probelm is fixed by actually drilling a hole in yer noggin! Is this true, or was someone yankin' my chain?
Flyer7SA
Active member
Total Time
1200+
Interesting you should ask...
I had a bad clog in my ear and couldn't figure it out. My hearing was muffled and I got concerned, so I went to the doctor. He took one look in it and said that I had a wax buildup and that they should irragate it. The funny thing was that I had cleaned my ears out a couple of days prior and couldn't find anything. When they cleaned it out, I felt like a new man.
I am 90% sure this is what it is from the symptoms you've described.
Good luck,
~Flyer7SA
328dude
Still turning two
Total Time
I had a really bad ear infection once and only after seeing my doctor, did he find out that my eardrum was torn. Why? Q-tips. Cleaning your ears out with Q-tips is the worst thing you can do to your ears. I thoght being careful to not go so deep would be alright, but you agrivate the linings of your ear by doing so. It was a big mess and was out of work for 4 weeks. Do yourself a favor. Buy the ear wax removing crap at Walmart. It works alot better then Q-tips. But, never stick anything bigger then your elbow into your ear.
Go to your doctor if your having problems with ear blockage. You might try Sudefed also. 4mg's in allowed daily per the FAA, but thats it.
avbug
Total Time
n/a
With respect to taking any meds, the FAA doesn't approve any medications. There are specific medications that the FAA disapproves and disallows, but that doesn't necessarily imply that the FAA approves other medications.
The primarily guideline is that the issue of medication is often far less important than the condition for which it's being taken. The medication may have little effect, or no harmful side affects, but the condition may be a grounding item. Sudafed is a good example. While it may alleviate the symptoms of a headcold or sinus congestion, one may feel fine and still experience a sinus blockage or other problem. Having had this before and having been deaf for a month on one occasion, and having been to the ER on another, I can testify to the fact that it's nothing to play with.
See a doctor. You may have any number of concerns, but the only person qualified to determine the cause, and treat it, is a doctor. If you do see a doctor, remember that a physician who isn't an AME isn't qualified to advise you on what you can and can't take when flying. Use caution when taking any meds and flying, and generally, be conservative. The most important part of any preflight is the pilot, and that means you, and me. Staying on the ground is sometimes a more wise course of action than finding a way to get in the air. Good luck with the Doc!
maverick_fp00
Total Time
.4K
Well guys, thanks a lot for the input.
I have heard of the peroxide thing before, but never tried it. Maybe I'll give it a shot.
As far as the Q-Tips go, yes, I use them also maybe I'll cut back on that.
Thanks Again,
AWACoff
Total Time
3000
I was born with a "hole" in my eardrum. I suffered chronic ear infections all through out childhood. There was some simply surgery done to relieve the problem (that of moisture being allowed to stick around in my noggin) back when I was a little kid. No more ear infections and I have an unrestricted 1st class medical now. Go to your doctor. Don't be an idiot. You are risking your hearing and your career.
