duty times
The whole argument rests on chapter d:
(d) Each assignment under paragraph (b) of this section must provide for at least 10 consecutive hours of rest during the 24-hour period that precedes the planned completion time of the assignment.
This says it all--planned completion.
Agree with you and YIP....our FSDO which is different than YIP's interprets it the same way.
Like someone mentioned....if something happens after the 14 hours they'll get you for careless and reckless however.
Yeah but like a previous post said, it's not your FSDO that decides, it's the ALJ. No doubt going over duty day by 4 hours is careless, but 30 or 60 minutes is debatable.
what four things lets you pass on the 14 hour duty day?
Well, if you are an operator in OH22 or AWM, it never hurts to have a couple of Feds and the FSDO Mgr on your payroll. Years of blowing 14 Duty been reported but never fined, sanctioned or otherwise violated.
100-1/2
http://www.faa.gov/about/office_org...s/2012/kidd - (2012) legal interpretation.pdf
Page 2, next to last paragraph.
You can continue beyond the implied 14 hour duty day for late pax/cargo, ATC delays, mechanical problems or weather.
The pathetic part of that legal interpretation is that it doesn't set a limit. So, if the flight was realistically scheduled to be completed with required rest, it doesn't matter if it take 100 days to complete the flight. I know that's ridiculously over stated, but you get the point. One hundred seconds, minutes, hours or days are all "legal" in this poorly worded interpretation.
If your on the ground and you know that you will exceed 14 hrs, you can't take off...If you unknowingly exceed it in the air due to re-routes etc...You can exceed the 14 hours. If your on the ground at TEB waiting for pax and you are going over duty time, you have to cancel the trip.
Example...A cargo crew was violated for exceeding their duty time by 4 hours because their truck was late by 4 hours. They thought that this was "out of their control" and they were legal to continue.
They changed the interpretation. It was illegal then, not now.
Thank you sir...i knew it was out there somewhere, but no way could i find it :beer:
EDIT in that i found the one osy was probably referring to, but not for the reasons he may think...
http://www.faa.gov/about/office_org...0/civil_penalty/CaseFile/view/1995/1995-8.pdf
On page 4, it says exactly the same thing from 1995 as KSU's link from 2012...
Thus, paragraph (d) cannot be construed as a hard and fast rule that 14 hours of duty time must never, under any circumstances, be exceeded...The key to applicability is in the final phrase planned completion of the assignment. If original planning is upset for reasons beyond control of the operator, the flight may be conducted even though crew duty time may exceed 14 hours.
...but note the cargo crew wasnt fined for merely blowing the 14 hour rule, but for not having a planned completion time ;)
And there has been some debate over whether or not a flight is planned if it departs late. The thinking is, by arriving late the passengers rescheduled the leg and the flight is no longer in compliance. And you can debate operational control and all kinds of other issues.
Some would argue, as I did, that you had to depart knowing the duty time would not be exceeded. Depart was widely excepted to mean doors closed. So, you could block out on time and, for reasons beyond your control, be delayed taking off or have to hold enroute and not be worried about it being considered a violation. However, if you had to open the door (for refuel or maintenance) you were done for the day.
This new interpretation ends that debate by including late passengers/cargo. If they arrive late, you know you are exceeding the duty day and you can still take off. I don't like it, but what are you going to do?
My company has been smart enough to put a limit on our duty for late passengers in our GOM along with extended rest rules that mirror scheduled operators. We can't get those approved in the Ops/Mgmt specs as we cannot PLAN on being late. But, if the passengers are late, we can depart and we will be given compensatory rest voluntarily by the company. It is a highly nuanced position, but a good one.
For arguments sake, I also happen to think that a 91 tail end ferry also must be included in duty time if it is required by the company. Flight time you may get a pass, but it is still company required duty in most cases and goes towards the 14 hours.
It is supposed to be included as duty since you are not free of all company related duties and it is not rest. however, Part 135 does not have a defined maximum duty period. The only limiting factor is requirement to always be able to look-back and see 10 consecutive hours of rest in the previous 24 hours to operate an aircraft under Pt 135 rules. Pt 135 regs don't say anything about how long your duty time can be. If your company wants you to do Jepp revisions after 14 hours of duty, it's completely legal so long as you don't fly a pt 135 flight again until you can look-back and see 10 hours of consecutive rest. Operating pt 91 has no flight time or rest limitations. The fact that you fly a pt 91 leg after a pt 135 duty period does not require you to comply with pt 135 rules on the pt 91 flight.
One could easily argue that you DO have control over your passengers, i.e., be on time or you can't go. I believe the FAA left this a little vague because they knew things can get delayed, passengers stuck in traffic, headwinds, ATC delays etc. I've always believed if you did your diligence, and you are slightly over 14 hours, the FAA isn't going to expend their resources to prosecute you. Is there a case where a crew was violated for going over 20 or 45 minutes?
^^^ i can agree with that. I dare say that most 14 hour days are multiple legs, and a 15 minute snafu on each leg can add up pretty fast. However, our passengers got constant updates if it was gonna be a long day, so they were aware what time we would turn into pumpkins...
...that said, I dont think I ever went more than about an hour over ;)
The problem with the current interpretation is the full exploitation of it. We've all been there, so I won't bore you with details. But after having a 13:45 scheduled duty day (including 3 international legs out of 4) creep to almost 16hrs and require an ASAP report. I now "just say no". And I dare my company to try and discipline me for my refusing to exceed 14 hours of duty.
100-1/2
Interesting. I used to work at the operator you must be referring to in AWM (there's only 1, so...). We dealt with your vigilant reporting on a regular basis, captain, and were found to be legal every single time. There are no violations of the 14hr duty day there. I'm not sure if you guys are confused by the fact that each airplane has a plane id that it flies under, not the captains number as many operators use. We always figured you guys were stupid and were assuming it was the same pilot just because the flight id was the same- we regularly did crew swaps but the plane would depart under the same id for a variety of reasons. You are annoying, by the way.
It isn't a 91 flight if it is required by the company. You may be able to operate under 91 flight rules, but for duty purposes it is a 135 flight and cannot be required if it will cause the pilot to exceed 14hrs duty. So what you are saying is correct in spirit, but the "91 ferry home" was intended as a way to let the pilots get home after a long trip *solely at their discretion*. Obviously this rule has been twisted and contorted to the point of meaninglessness over the years, as have most regs dealing with 135 on demand stuff, but that is how it is supposed to work.
Woog315,
So, then, this just might have been you???
MDS427
10-Oct-07 SW3/G Tullahoma Rgnl (KTHA) West Memphis (KAWM) 10:55PM CDT 11:50PM CDT 0:55
10-Oct-07 SW3/G Laredo Intl (KLRD) Tullahoma Rgnl Arpt (KTHA) 07:02PM CDT 10:11PM CDT 3:09
10-Oct-07 SW3/G El Paso Intl (KELP) Licenciado (MMTO) 08:38AM MDT result unknown (?) n/a
0930 CT First Departure. 2350 Final Arrival (2350-0930 not including 'Show Time+Post flight') = 14:20+ duty on 9.5hrs of planned flight time?
This was never as bad as when I saw one of you guys dropping a load in YIP from MFE (non-stop @ ~5:30 FT) and then saw the same guy dropping another load in LRD (non-stop @ ~5:00 FT) about 3 hours after my arrival. Could have cared less about your operation before witnessing that amazing feat that i am sure turned out nice and legal in the logs. No Co-pilot by the way.
And yes I am annoying, why don't you assist in recovering remains of any tragically avoidable loss of life sometime for perspective and then check your remarks?
100-1/2
Some of you guys are pretty funny...and kind of dumb. How can anyone tell you that you cannot WORK more than 14 hours of duty time....? THEY CAN'T.
Theres many reasons that 100% allow you to WORK longer than 14 hours in a duty period.
what are you supposed to do if the clock hits 14 hours and you are holding for bad weather.......jump out of the damn plane at 13:59 and hope to hit the ground at the 14 hour mark......LOL
I have personally sat on the taxiway in Anchorage for 7 hours AFTER we landed from a 12 hour flight..........WE WENT PAST DUTY TIME BY A LONG AZZ WAY........there was no parking space because there were planes backed up to #20 for de-icing........If I remember we shut all 4 engines down and sat on APU power for most of the 7 hours.
JEEZZZZZZZZ.....
