61.57(d) requires an "instrument proficiency check"
The same logic the FAA uses to say that an Instructor check is not a pilot check, might be applied to say that an instrument instructor check is not an instrument check. I'd be on the safe side, and get him/her to endorse you logbook for an IPC. I don't see how the examiner could object to that, then you're covered regardless of what the interpetation might be.
If I understand your question correctly, you are asking if taking a practical test for an instrument rating on your flight instructor certificate ("CFII") counts as a flight review.
No, it does not. You can ask the examiner to endorse you for a flight review, however, and then you're covered.
As A Squared indicated, the same applies for instrument currency.
