ceo_of_the_sofa
Registered User
- Sep 25, 2002
I thought so too, just wanted to justify not wanting to part with my hard earned $90 to have AGI adorn my certificate.shamrock said:you sign off your flight students after giving them the required groundschool, so why would this be any different? An AGI certificate allows someone who is not a CFI to teach groundschool and sign someone off for the written.
Thanks, I will look into this and get started....should be fun to hit the books again...Any suggestions on reading material, ie text books? or is the Gleim ATP red book good enough for these tests??nosehair said:Col. Bill, you take the Fundamentals of Instructing (FOI) knowledge test, which comes from the Aviation Instructors Handbook, the Advanced Ground Instructor's knowledge test, which comes from the General Aviation knowledge required for the Private and Commercial Pilot knowledge tests, and for the IGI, you take the Instrument Ground Instructor knowledge test, which is from the knowledge required for the Instrument Knowledge test.
You take the passed test results, along with an application, Form 8710-1, to a Flight Standards District Office (FSDO) and you will be given the AGI and IGI Certificates.
rvsm410 said:Thanks, I will look into this and get started....should be fun to hit the books again...Any suggestions on reading material, ie text books? or is the Gleim ATP red book good enough for these tests??
Is this because of my dispatch license or the commander/PIC time I have? My license does not have ATP on it, as I never converted this to a civil rating mostly due to the fact I was finished flying (medically speaking)...and what is the FOI test???sweptback said:You shouldn't need a signoff for the AGI/IGI/FOI tests. Just show up.
The Gliem should cover everything you need to know, I wouldn't worry about much else.
It's not because of anything you have or don't have... it's simply because a signoff is not required for the exam. Just show up at the testing center and take it.rvsm410 said:Is this because of my dispatch license or the commander/PIC time I have? My license does not have ATP on it, as I never converted this to a civil rating mostly due to the fact I was finished flying (medically speaking)...and what is the FOI test???
It's hard to generalize. The best answer would be that it depends on how much of an asshole either might be. Except for the most unreasonable examiners around, no one should look down on you for getting your ground instructor certificates first. Most could care less.Jedi_Cheese said:I am thinking about getting my IGI/AGI before I get my CFI/CFII (as a stepping stone). Will a DE/FSDO examiner look down on this (or give me a tougher chrckride) when I come in for my CFI ride?
Yes, because your CFI-I is an instructor rating separate and apart from your AGI-IGI.Also, will I need a signoff from a CFI saying he covered the required information with me or not?
Thanks, I am working on my commercial and just got done with my instrument so this would be a good time to pick up these tests. I should have clarified that I know I need signoffs for my CFI-I, but I was wondering about the AGI and IGI specifically.bobbysamd said:I would get your ground instructor ratings. They are something else to put on your resume, something else that can help you find work, and another reason to review the material. Good luck with both.
I don't think you need signoffs for the ground instructor and FOI writtens. 14 CFR 61.213, which sets forth eligibility requirements for ground instructors, is silent in that regard:Jedi_Cheese said:Thanks, I am working on my commercial and just got done with my instrument so this would be a good time to pick up these tests. I should have clarified that I know I need signoffs for my CFI-I, but I was wondering about the AGI and IGI specifically.
My license does not have ATP on it said:Seems to me that you could still take your military records to the Flight Standards District Office and see if they will convert your ATP even though you may not meet the requirements to hold a medical certificate, that should not preclude the FAA from issuing the certificate - just precludes you from exercising many of the the certificates priviledges!
FOI is an acronym that stands for "Fundamentals of Instruction", the FAA's bible on learning how to instruct!
Sorry, but the only FAA pilot certificate that can issued on the basis of military experience only is a Commercial certificate.Seems to me that you could still take your military records to the Flight Standards District Office and see if they will convert your ATP even though you may not meet the requirements to hold a medical certificate, that should not preclude the FAA from issuing the certificate - just precludes you from exercising many of the the certificates priviledges!
I should have read the original post a couple more times before typing a reply - Bobby you are right on (as usual).bobbysamd said:To be issued an ATP, he would have to take an ATP practical.
