Forgive me if I do a lousy job of explaining this.
First, some Bonanzas, like mine have conventional tails.
In a V-Tail aircraft, the 2 control surfaces of the V-Tail work together to give elevator and rudder responses. For elevator control both surfaces move up and down together. For rudder both surfaces move opposite (right rudder moves the left surface of the V-Tail up and the right surface down) . For both elevator and rudder to be used at the same time, both these movements need to be 'mixed' together to get a proper response out of the aircraft. Beechcraft does this by using a cam, a spring and lever arrangement.
Beechcraft also uses a spring, or bungee, interconnect with the airlerons that helps the pilot coordinate a turn. Most airplanes do this to some extent as the upwing aileron in a turn creates additional drag that has to be offset with the rudder to keep the airplane from skidding sideways in uncoordinated flight. In a C172, this effect is minimized by the location of the aileron hinges, but the pilot still has to put in a little rudder to coordinate a turn. The Bonanza has much nicer ailerons with a pivot point near the exact aerodynamic chord. It requires a little more rudder than the C172, but Beech put a spring in there to do the work for you. So you can fly feet flat on the floor and let the spring do the work. On even bigger airplanes this same task is handled by spoilerons which add drag on the downward wing in a turn.
In my opinion (flame suit on) my Bonanza is a little less controllable in a crosswind because the spring tries to coordinate flight, while the pilot has to input opposite control forces to crab and align the airplane with the runway. Fortunately, the Bonanza has a great gear system that puts up with more abuse than other designs that were not originally designed for off airport, rough field operations. Back in 1946 many of Beech's customers did not fly off paved runways.
The V-Tail was thought to be more aerodynamically efficient. It really wasn't and the numbers for my straight tail are the exact same as the V Tail of the same year and power. The straight tail also has a less restrictive C.G. range since the elevators are more effective.
They are great flying airplanes and even tough I have demo'd a Cirrus, I'll either buy a nicer Bonanza, or keep mine forever.
