agonyairfo
- Jan 4, 2004
The idea that dihedral causes the lower wing to have a higher "vertical" component of lift is incorrect. It has to do with the airplane's movement through the air...angle of attack.
requoted from above from the Pilot Handbook ..."If a momentary gust of wind forces one wing to rise and the other to lower, the aircraft banks. When the aircraft is banked without turning, the tendency to sideslip or slide downward toward the lowered wing occurs. Since the wings have dihedral, the air strikes the lower wing at a much greater AOA than the higher wing."
I know on paper it looks like the lowered wing is now perpindicular to the horizon so it has more lift pulling it up, but lift is only relative to the angle of attack/oncoming air. Nothing helps keeps the "wings level" other than an autopilot. The only way dihedral helps keep the wings level is once you put the airplane there, it will tend to stay there.
