Difference Between Air and Ground Mileage
your_dreamguy
Hello,
On the Flight Summary Page of our FMS, there are two columns for our flight. One gives an Air Mileage Distance and the other gives a Ground Mileage Distance. The mileage numbers are different and I was wondering if anyone knows what the difference between the two numbers is?
Thank you :p
I believe that the "air-mileage" number accounts for winds, while the "ground-mileage" number does not. For example in a headwind you will take longer to complete the flight so you will "travel" through more air distance. With a tailwind the air-distance number will be less than the ground distance number since the wind is pushing you along.
If youre doing 400 KTAS and have a 100 knot headwind, your air mileage will be 400 and ground mileage will be 300 after 1 hour
Yes, good answer.
