Density altitude and air pressure contra
Bernoulli
I'm comming up with a contradiction in my understanding of air pressure and density altitude. Maybe some of you exceptional CFI gurus out there can straighten me out. Below are two scenarios that seem to contradict one another:
Scenario 1.
If you fly from warmer air into colder air the altimeter is going to think you are higher. Lets say your indicated altitude was 5,000 feet... when you enter the cold air the altimeter will indicate something higher like 5,300 feet. The altimeter does this because it thinks the air pressure is less because that is what an altimeter reats to... air pressure. Well, the higher the altitude gets, the thinner the air becomes...and the colder the air becomes.
2. If you takeoff on a cold day the airplane's recipricating engine will perform better because the air is thicker, or more dense. If the air is hot the air is thinner and the aircraft performance decreases.
So in scenario 1. cold air is synonymous with high altitude which is synonymous with thin air... yet in scenario 2. cold air is synonymous with low altitude which is synonymuous with dense air. Someone please explain this contradiction to me.
Bernoulli,
This is a case where you're trying to think too much. You're trying to outreason the altimeter.
If flying at 5,000 feet indicated, your altitude will not increase when entering a colder airmass. Your indicated altitude remains the same, and true altitude decreases, not increases.
Your indicated altitude remains the same when flying from hot to cold, but your true altitude decreases. One way of picturing this is to imagine a balloon. Stick a little model airplane on top of the balloon, and fix it in place with a little rubber cement.
Measure the distance between the airplane and the tabletop. This is your true altitude. Place the balloon in the freezer. It cools, it shrinks. Plut it back on the table. Now the distance between the little airplane and the tabletop is less...true altitude has decreased.
Same for a pressure drop. Instead of sticking the balloon in the freezer, just suck out a little air, and keep it the same temperature. Lesser pressure, true altitude decreases (assuming it's set to the same altimeter setting. In other words, if you change the altimeter setting to match the current pressure, your altimeter will read correctly. However, if you don't change it to match the current conditions, it won't read correctly. If it's set for a higher pressure, it's going to indicate higher.
You can also see this while sitting on the ramp. Simply dial in a higher pressure on your altimeter, and watch what it does. It shows an increase in altitude, even though you know you haven't moved at all. You can envision a pressure decrease as though the air mass you're in has "decreased" in volume...it's shrinking. If you're at a certain level or layer in that airmass, (sometimes we call this an altitude), the height of that layer is going down along with the rest of the airmass when the airmass "shrinks."
Your altimeter is based on pressure, and based on a reference pressure. If you're following a reference pressure level (altitude), and that altitude goes down, you go down...even though the altimeter says otherwise.
Don't confuse temperature lapse with altitude, with flying from one airmass to another. The altimeter is referenced to a pressure; it's not really that pressure we're flying in. It has no clue about temperature. For example, at 18,000', we're going to put 29.92 in the altimeter. It's not really 29.92" Hg up there, but we use that as a reference...that's the reference supplied to the little aneroid wafer in the altimeter, by compressing it using a spring. This is something you don't need to worry about; all you do is set the altimeter. Once it's set, the outside air temp is irrelevant if you have the correct altimeter setting in place.
When flying from one location to another above FL 180, for example, all aircraft are using the same altimeter setting. In any one given area, aircraft will actually be higher than 18,000 MSL, or lower than that, depending on actual temperature and pressure. However, everyone in a given area will be affected the same way...the important thing.
Where it does become an issue is at lower levels.
Cold air is not synonymous with high or low altitudes. Temperature generally decreases with an increase in altitude, but that has nothing to do with your question. With a decrease in temperature while flying at a constant indicated altitude, true altitude will decrease. Your question asks about getting colder with altitude, but your question must also presuppose flying at the same indicated altitude...vertical temperature lapse rate then has no part in the matter.
Your powerplant will perform better at colder temperatures, due to increased air density. However, with an increase in altitude, lower air density works against this performance increase. In other words, air pressure is less, though temperature decreases. Where a decrease in air temperature will provide increased engine and aircraft performance is an decrease in density altitude...not merely temperature.
Thanks for the reply avbug. I think a better and more simple way to state my question would be: What is the difference between air pressure and air density?
I agree with Avbug. You're overanalyzing a bit by trying to tie the two together.
It's true that in both cases air density decreases as both altitude and temperature increase, and vice versa. But, as Avbug points out, the rate at which they vary is different, so that the density increase from colder temperatures aloft is not enough to offset the decrease from the altitude increase itself.
Maybe it will help to realize that the effects being dealt with in the two scenarios are diferent.
In scenario 1, you dealing with an instrument error, nothing more. You have an altimeter set for a specific sea-level corrected barometric pressure (remember that the station is on the ground, not at 10,000 msl). It does not adjust for temperature changes at varying altitudes. If there is a pressure change due to a temperature variation aloft, it just doesn't get reflected on the instrument.
In scenario 2, you are dealing with engine performance issues. Yes, temperature decreases with altitude, but not enough to offset the pressure change due to the altitude itself. All the density altitude scenario means is that =at a given altitude= the air is more dense when colder. In other words, when I take off at Leadville, CO (9927' msl), the airplane will perform better on a colder day than on a warmer one.
Does that help at all?
Air pressure - Imagine a box of air with all the molecules flying around inside bouncing off each other and the walls. When the molecules hit the side of the box they exert a force on the side of the box and there are enough molecules the total force of all the molecules hitting the walls, on average, is constant.
Air pressure is the average force on the side of the box divided by the area of the side of the box. Density is the mass of the molecules in the box divided by the volume of the box. Temperature is the average momentum (speed*mass) of the molecules in the box.
Density ~= Pressure/Temperature
The amount of oxygen in a given volume of air goes up with increasing density. Engines suck in a certain volume of air. The more oxygen in a given volume of air, the more fuel can be burned and the more power an engine makes. We have to lean the mixture as we climb because the density of the air is decreasing so we need to reduce the amount of fuel to match the mass of oxygen in a given volume of air. Most new cars (and even some airplane engines now) have mass airflow sensors that directly measure the mass of air entering the engine independent of the volume and the computer meters in precisely the correct amount of fuel.
Aerodynamically an airplane works by redirecting the mass flow of air. Be it a propeller accelerating a mass of air back to produce thrust or a wing accelerating air down to produce lift.
Scott
