I'm comming up with a contradiction in my understanding of air pressure and density altitude. Maybe some of you exceptional CFI gurus out there can straighten me out. Below are two scenarios that seem to contradict one another:
Scenario 1.
If you fly from warmer air into colder air the altimeter is going to think you are higher. Lets say your indicated altitude was 5,000 feet... when you enter the cold air the altimeter will indicate something higher like 5,300 feet. The altimeter does this because it thinks the air pressure is less because that is what an altimeter reats to... air pressure. Well, the higher the altitude gets, the thinner the air becomes...and the colder the air becomes.
2. If you takeoff on a cold day the airplane's recipricating engine will perform better because the air is thicker, or more dense. If the air is hot the air is thinner and the aircraft performance decreases.
So in scenario 1. cold air is synonymous with high altitude which is synonymous with thin air... yet in scenario 2. cold air is synonymous with low altitude which is synonymuous with dense air. Someone please explain this contradiction to me.
Scenario 1.
