I could have phrased "That explaination is incorrect" a bit better... it's amazing how many people think that the 7ER pilots only fly 767-300ER aircraft.
I understood the question to be about the aircraft not what pilots fly.....
Former PCP
If we merge with Alaska, can we hire the APA to handle our merger?
Interesting to note, just looked up Alaska's profile on APC. Largest airplanes are the newer 737s -800s? (I think)--APC shows their Capt. payrate on that aircraft to be almost exactly the same as DAL's rate on the -800. If it happens, (buy-out or merger w/DAL) looks like your most senior capts. would start to "merge" into our list (by status & category) at about number 2000 or so, with MD-80 Capts. going a little lower, maybe about 3 - 4000 or so. How does that sound to you, AKMD80GUY?....What!!! You want what???!!!---Date of Hire????:laugh: I'm sure the former NW pilots would support you!!!....right, NW guys??:bomb: (The Delta pilots (all of us) more than likely, will not [ask the [likely] arbitrators, to] staple you!)This is a staple free zone.
Most likelyhood they would blend them in in some ratio from the 737-800s down. Their career expectations do not include anything larger at this point.
Bye Bye--General Lee
After the SLI, all positions should be open for bid using system seniority. That's the only fair way to proceed.
Ouch.
From what I've seen, DAL SLIs are pretty fair. The earlier poster who posited merging Alaska pilots in with the DAL 737-800 guys probably has the right idea. Of course, Gen. Lee and his ilk will probably demand a "forever" fence around the widebodies due to "career expectations".
Personally, I tend to believe that once the SLI takes place, everyone has the same career expectations, so that kind of fence is merely divisive and helps the Company keep the pilot group at odds with each other.
