Rez O. Lewshun
Save the Profession
- Jan 19, 2004
Hi!
The practical answer is you should always try and fly the actual track/path of the runway (unless instructed otherwise), even though the FARs are unclear.
cliff
GRB
Which shows up stronger on radar Rain or hail?
Wouldn't that mean over inflated tires hydroplane at higher speeds?
Although I don't know the answer DL wants, this question has been an interesting debate around the web boards....The manual from the WX radar in the aircraft I fly says hail and other frozen precipatation do not show up as well as rain. I think the DL question is taken from the ATP test and according to Gleim, the answer is rain.Hail normally, because it is usually WET and surrounded by water which shows up as one big rain drop.
Directly from Aviation Weather
Although I don't know the answer DL wants, this question has been an interesting debate around the web boards....The manual from the WX radar in the aircraft I fly says hail and other frozen precipitation do not show up as well as rain. I think the DL question is taken from the ATP test and according to Gleim, the answer is rain.
Also consider that water E X P A N D S as it freezes. Ice is less dense than water. Ice floats.
But your explanation holds water also
Good luck.
Regarding runway heading... If departing runway 24 and the published magnetic alignment is 242 then you do not necessarily fly heading 242. You take the runway, center your heading bug and fly that. Capt side might be 244 and FO might be 239. Just center the bug and go. Your AHARS might not be exactly in-line with the published runway heading or even the FO's heading indicator. Don't worry about the wind either.
Ex. Lets say your tire pressure is 100 kts. ....
EX. Lets say your tire pressure is 81 kts....
