Delta app.?
hyeflyin
Got an e-mail from Delta@AirlineApps about 2 weeks ago with the following message:
Pilot Candidate
A review of your application revealed that your address history does not correspond to the information in your employment history. This omission must be corrected before your application can receive further consideration.
Sincerly,
Delta Pilot Selection Team
I have reviewed my application many times over and cannot find anything wrong. I also spoke with the folks over AirlineApps and they also said everything appears correct. So I emailed Delta@AirlineApps back to clarify the problem, however I never received any response. Has anyone else received the same message? Is there any other way of getting a hold of someone at Delta to correct the situations? Thanks.
Your dates need to be sequential. There must be no gaps in employment or residence history. If you do have a gap in residence history, change it. That is probably what they are referring to.
