Definition of original point of departure for Cross country
districtpilot
Here is an old subject that I recently rethought. For a certificate or rating x country needs to be at greater than 50NM from the original point of departure. My question is this, what is the original point of departure? Say I am doing a run and I fly from Denver to Pueblo to Centennial back to Denver, is that to say that all is x country except the Centennial to Denver leg as an example?
Yes, I know that for 135, x country is point to point, I am studying for my ATP and even though I have much more than 500 hours XC by any definition, I was wondering if some of my legs that I logged that were under 50NM technically would not be XC for that purpose. I don't work for Key Lime, I used to go to college out there. I am on the East coast.
Good question. I guess it depends (maybe not)?
I logged my student/instrument/commercial cross countries as one line and did a few A to B to C to A where A and B were 50+ but C and A were not...it counted.
Now I usually log them twice. The flight going there gets one entry (A to B) and the flight home gets another line (B to A). So...if I went A to B to C....I doubt I could get C to A to go towards "XC time for ATP".
Excellent question....I hope I haven't just added confusion but I'm ineterested to know also.
-mini
You're thinking too hard. The "original point of departure" is the airport where you started the flight. This topic gets over-thought usually in the context of repositioning from the home base to try to avoid going somewhere new. The FAA's semi-official stance is that (1) there is no solid definition since what is a flight is in the mind of the beholder and (2) you gotta look at it on a case-by-case basis.
There is no serious question, however, on one point: intermediate landings and stops =do not= make one "flight" into many for xc flights with a >50 NM requirement.
If you're doing a run form DEN-PUB-APA-DEN you are in the typical round-robin situation and the whole flight is legitimately considered a cross country.
