Definition of complex airplane?
A Squared, You pose an intresting point. But I base my reply on what an aircraft engine is rated as listed in the Type Certificate Data sheet, see copies of reference below. I looked in the Preamble of 61.31 but the origional was from the mid 60's and has been revised so I could not determine what the author ment by 200 horespower. I also looked at Part 61 FAQ and FAA Legal Interpitations from the Summit CD and found nothing of what "horsepower" ment in relation to the question at hand.
IMHO the intent of the regulation is to ensure some level of training for a pilot transitioning from a C-172 to a "more powerful" aircraft.
For most pilots who were trained the civilian route this is a non issue, they had an endorsement long ago to fly More than 200 horse power engines. The Ex-military pilot who never flew a single engine aircraft but went from flying C5-A's to Boeing 747s for an airline most likely never had an endorsement, and in IMHO does not need one because of the training required to fly such aircraft.
I did not find any specific FAA reference that would define what was ment by "horsepower" in the context of the question, if you have any please post the reference.
JAFI
________________________________________-
TYPE CERTIFICATE DATA SHEET NO. A22CE
I - Model 500, Citation and Citation I, (Transport Category), Approved September 9, 1971
Engine Limits Static thrust, standard day, sea level:
Takeoff (5 min.) 2200 lb.
Max. continuous 2090 lb.
TYPE CERTIFICATE DATA SHEET NO. 3A21
I - Model 210, 4 PCLM (Normal Category), Approved April 20, 1959
Engine Continental IO-470-E
*Engine Limits For all operations, 2625 r.p.m. (260 bhp.)
One of the interesting events in my career as a Flight Instructor was back during the Viet Nam war when I was a young flight instructor at an airport near an Air Force Base. Frequently we had Air Force pilots come out to rent a 172 to do some local "fun" flying. Most of them had no problem with the little thing, but there were a few, and I think a few too many, who had the devil of a time pushing the rudder to keep the nose aligned on take-offs and landings during power applications. Those F-4 pilots tell me they just don't have to use rudder except to taxi.
Propeller P-Factor: A pilot with lots of flying time in airplanes that do not require constant rudder pressures to counteract P-Factor can lose control of a simple 172 during a go-around during the flare. I worked with many of them, and some I could not allow to rent our 172, even after 8-10 hours.
Just my 2 cents.
Jet time is Jet time; Log it as such. It carries more "weight" than 'Complex", in the over-all picture, but is not characteristic of "prop" time, or "complex" time.
It's "high speed" time, but not complex time.
I agree with JAFI on everyone of his posts. Back when I was Flight Instructing, I had an apppointment with an L-1011 Captain, so he could get a HP complex check. When I asked him why (considering he was an L-10 Captain), he brought up the fact about the Controllable Pitch Prop. So, anyway, needless to say I was a little shocked when I heard that.
A Squared:
Seems like I'd hear all kinds of 135 guys asking for (and getting) VFR On Top clearances in order to stay below the MEA's through the mountains. Did you say that VFR-OT was not allowed for Part 135 and 91? I don't think that's correct, but I could be wrong.
Big Duke Six said:
A Squared: Seems like I'd hear all kinds of 135 guys asking for (and getting) VFR On Top clearances in order to stay below the MEA's through the mountains. Did you say that VFR-OT was not allowed for Part 135 and 91? I don't think that's correct, but I could be wrong.
No, I didn't say that VFR on top wasn't allowed for 135 operators. I said that they couldn't descend below the MEA on a VFR on top clearence whereas part 121 operators may. It's one of hte rare circumstances where part 121 is more permissive that part 135 and part 91. Here's a legal interpretation which explains it.
FAA Legal Opinion:
AGC-23
Interpretation: IFR Operations - VFR on-Top
Chief, Airspace, Air Traffic, and Environmental Quality Branch, AGC-23
ARM-7B
This is in reply to your memorandum containing the following question presented by your Flight Standards Division.
May an aircraft on an IFR flight plan but cleared by ATC to maintain "VFR conditions on-top" (FAR 91.121(a)) be operated below minimum en route IFR altitudes; i.e., without regard to FAR 91.119(A)?
Such operation is not permitted under Parts 91 or 135. It is our opinion that Sec. 91.119 does apply to IFR operations that are clear for "VFR conditions on-top." The minimum altitude rules of Sec. 91.119 are designed to ensure safe vertical separation between the aircraft and the terrain. These minimum altitude rules apply to all AFE flight, whether in IFR or VFR weather conditions, and whether assigned a specific altitude or flight level or "VFR conditions on-top." A pilot operating on a "VFR conditions on-top" clearance may operate at the altitude or flight level of his choice; however, he is required to adhere to Sec. Sec. 91.119 as well as Sec. 91.109 of the FARs. While Sec. 91.121(a) specifically incorporates the VFR flight levels of Sec. 91.109, there is no basis to conclude that Sec. 91.119 does not apply.
Section 121.657, however, provides for an analogous "over-the-top" IFR operation under certain restrictive conditions at minimum altitudes that may be below those prescribed under Part 95.
This interpretation has been coordinated with AFS-800 and AAT-200 who are of the opinion that the regulations do not need clarification in this respect.
RICHARD W. DANFORTH
a jet is in a class by itself. A jet requires a type rating due to the turbine. See 61.31 (a).
A turboprop is measured in shaft Horsepower. So that will fall into the complex nature. But if Im right most log it as turbine time.
So a turboprop will need a type rating if it weighs 12,500 or more. but will be classified as complex & high performance otherwise.
No it's not, a jet is a single or multi-engine land or sea class, just like any other airplane.
How the power output of the engine is measured makes no difference in determining the complex status of an airplane. A turbo-prop is complex if it has retractable gear, flaps, and a controllable-pitch prop, just like any other airplane.
That's because it is turbine time. You can log it as turbine time AND complex time.
It's complex and high performance even if it needs a type rating. The requirements for complex and high performance do not except airplanes that require type ratings.
Do you have a legal interpitation or FAA reference to back this up? I would like a copy.
JAFI
